LED bulb dimmers
Have you found an inexpensive way to regulate bulb intensity on your gauges? [LED's require 'pulse-width modulation' to adjust intensity level]
I think I've found what is needed on eBay...
http://www.ebay.com/itm/PWM-Dimming-Controller-For-LED-Lights-or-Ribbon-3528-5050-12-Volt-8-Amp-DIMMER-/140636548137?pt=US_Car_Lighting&hash=item20be976c29#ht_2535wt_1156
Please note that the ad states the device can handle "8 amps". But, if you read the info on the device, it shows that it is for ".8 amps".
But , my experiences stem from adding 12v strips of LEDs onto my large Rc helicopters for night flying... They seem to run anywhere from 8v to 14v with varying intensity... I run mine at 12v and they're really bright ... And when my 12v input source battery runs low, they dim nicely with no adverse effect to the leds ... They just kill my lipo battery I was using to light them... They don't like that at all... Lol
PWM works a lot better and more linearly than voltage modulation.
The pot is attached to the board with wires, not soldiered to the board, so you can extend and relocate the pot if you want. I will probably put it under the dash where the vacuum switch was.
