How much vacuum needed for headlights
Old May 12, 2014 | 01:21 PM
540 vette's Avatar
540 vette
Default How much vacuum needed for headlights
I just started my 383 and the headlights don't work properly. Everything is new and has been tested. And installed as per the chart. I have about 5-6 inches of vacuum, is that enough to get them working or do I need a vacuum can.
Old May 12, 2014 | 01:36 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
No, you need about 9-10" vacuum, for them function in a timely manner.
12-16 is a good engine vacuum with no big cam,
yank that big loppy cam out of there !
check your base vacuum of the engine, with nothing connected to the eng vacuum.
if it is higher with everything dissconnected, you have leaks.
you should also have a vacuum can/tank, to store up vacuum energy.
espicially if you have a big cam = low vacuum.
Old May 12, 2014 | 01:49 PM
540 vette's Avatar
540 vette
I have one in the shed. I guess it will find it's way into this car.
Old May 12, 2014 | 05:25 PM
C3Hawk's Avatar
C3Hawk
So true! My "355" with it's lopey cam pulls 9 inches of vacuum and the lights work without any extra vacuum tank.
Old May 13, 2014 | 10:07 AM
C6DuffMan's Avatar
C6DuffMan
Vacuum is not constant when driving. Try opening them while decelerating (I.E. Engine Braking), they'll pop up fast! As others have said, storing that high vacuum is the purpose of the vacuum can and more importantly the check valve.
Old May 13, 2014 | 10:11 AM
Mike Ward's Avatar
Mike Ward
A leak free system will work quite well with 5-6" of vacuum.
Old May 13, 2014 | 11:21 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Old May 13, 2014 | 12:42 PM
MIKE80's Avatar
MIKE80
I have 6" of vacuum with the cam I have and my headlights need help raising. All new, tested good parts, no leaks, including new vacuum can. If I move my electric vacuum pump from the brakes to the headlights, they work great. Just not enough vacuum from the engine. I have one of the last "Killer Lights" kits before McSpeed stopped making them which I will install when I get the chance and sell off my vacuum parts.
Old May 13, 2014 | 03:20 PM
C3Hawk's Avatar
C3Hawk
Good to know; definitely the lowest number I've heard so far.
Old May 13, 2014 | 03:31 PM
Mike Ward's Avatar
Mike Ward
But leak free means leak free, not 'low leak' like 95% of the cars.
Old May 19, 2014 | 07:02 AM
C3Hawk's Avatar
C3Hawk
I have one of the "low leak" cars!
To How much vacuum needed for headlights
