Brake handle slider
Old May 18, 2014 | 02:14 PM
bellaireroad's Avatar
bellaireroad
Default Brake handle slider
I'm getting ready to pull my handle. Is the hole in the plastic silder big enough to pull over the handle, or does it have to be cut? If it has to be cut, what to do on reinstallation? thanks
Old May 18, 2014 | 04:17 PM
Blue73Shark's Avatar
Blue73Shark
The replacement slider on my 73 had a slit in it from the hole outward toward the edge. Have to use it as the hole is not big enough to slide over the handle.
Fran
Old May 18, 2014 | 04:37 PM
Alan 71's Avatar
Alan 71
Hi B,
73 is right; it needs a slit.
Also the slide has a front and back… the shape of the opening in the slide matches the shape of the chrome lever. Rounded end to the rear.
Regards,
Alan
Old May 18, 2014 | 09:04 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Originally Posted by Alan 71
Hi B,
Regards,
Alan
Alan I see you fixed yours since I last saw it
Old May 18, 2014 | 10:36 PM
70Yellowbird's Avatar
70Yellowbird
I had this same concern a few years ago when I was disassembling my '70. When I removed the parking brake handle, I found that the slider already had a slit in it. I didn't look closely, but thought the slit was factory original.
Was I wrong? Without a slit, how would they get it over the grip?
Old May 19, 2014 | 01:00 AM
bellaireroad
thanks everyone, mine had a slit that I didn't notice
Old May 19, 2014 | 03:27 PM
Alan 71's Avatar
Alan 71
Hi 70Y,
IF the e-brake handle is loose from the ratchet mechanism the slide could be slipped on from the bottom.
But there's no way to do it with the handle in place, without a slit.
If you're careful just where you make the slit it really becomes almost impossible to see when the slide is in the track.
That's why some people don't even realize they're slit.
Regards,
Alan
Old May 19, 2014 | 03:56 PM
F22's Avatar
F22
Hi 70Y,
Regards,
Alan
Ya don't want to be 'slit' out of luck!
Old May 19, 2014 | 05:52 PM
oldgto's Avatar
oldgto
Mine does not have a slit in it. I removed the black plastic grip and slipped it over the top. (Yes, I know there are some who think the grip won`t come off.) I`d had this handle apart a couple times, in fact it is the best parts of two different assemblies, so it came apart fairly easy.
Old May 19, 2014 | 07:25 PM
70Yellowbird
Is that the 'factory original' or a repro replacement?
Old May 19, 2014 | 07:30 PM
oldgto's Avatar
oldgto
The slider seal is a repro on original brake handle mechanism.
To Brake handle slider
