smog question
Old May 21, 2014 | 12:58 PM
blanco_25's Avatar
blanco_25
Default smog question
I'm looking at a 81 corvette, my only question is does tx require a smog test, because the previous owner removed the smog pump
Old May 21, 2014 | 01:13 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
It depends on your area of the country. In my part of NC, cars have to have a visual inspection for 81's (I have an 80 so I assume the same applies for an 81) but no sniffer test. Everything has to be there whether it works or not. Supposedly. At age 35 model years, there is no inspection requirement for smog controls, just the usual lights, wipers, and horn stuff. Check with an inspection station in your area or call the state DMV for your requirements.
Old May 21, 2014 | 01:39 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Contact the Texas DMV and ask.
Old May 21, 2014 | 04:54 PM
Snoopysvet's Avatar
Snoopysvet
Did it come with a smog pump?
My 1978 did not
Old May 21, 2014 | 05:14 PM
Tim 1973's Avatar
Tim 1973
In some counties smog testing is required. In all counties, cars older than 24 years are considered antique and are exempt from emissions testing.
So you will not require a smog testing. If you register it as a antique you will not be required a yearly inspection.
Old May 21, 2014 | 05:47 PM
00Nassau's Avatar
00Nassau
St. Jude Donor '11
There are no emissions tests in Texas if the car is over 25 years old.
Old May 22, 2014 | 06:19 AM
gcusmano74's Avatar
gcusmano74
Maybe there is some discussion on your state's DMV website. Or contact the local DMV office and ask.
Old May 22, 2014 | 09:06 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by Snoopysvet
...Did it come with a smog pump?...
Yep. All 81s had them.
Old May 22, 2014 | 12:34 PM
Tim 1973's Avatar
Tim 1973
Makes no difference in Texas as it's 24 years or older. Where I live in Texas they do not test or look at the emissions system. I never get out of the vehicle. All they look at is tires lights wiper blades. They never look under the hood.
To smog question
