Missing Snorkels
Old May 27, 2014 | 08:46 AM
Bloodzone's Avatar
Bloodzone
Default Missing Snorkels
Hi all, I bought a 79 L48 vette and being vette newbie just noticed that both snorkels are missing. I have a factory air filter with the 2 ports but the flex tubes and hard plastic snorkels have been removed. Would a simple open air filter be better or should I replace the original equipment. I'm guessing what I have now is restricting my intake.
Old May 27, 2014 | 08:57 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The purpose of the snorkel system was to bring cool air in over the radiator to the carburetor. I'm guessing that if a PO removed the snorkels and flex ducts, he/she also removed the air box along the top of the radiator.
Post a Want To Buy here or search eBay. You may be able to collect the parts you need.
Old May 27, 2014 | 09:11 AM
Bloodzone's Avatar
Bloodzone
Thanks for fast reply. I've checked around and it would be like 150 to replace all 4 pieces (2 flex tubes and both plastic snorkels) I could buy a nice normal filter for much less. Or I could just leave it as is if its not that big of a deal. I just want good air flow and I'm not sure I'm getting it with what I have now.
Old May 27, 2014 | 09:27 AM
joewill's Avatar
joewill
corvettes had a open element for over a decade, then they went to snorkels, sometimes they used both. the difference between the 2 is negligible unless you are trying to get that extra 1 or 2 horsepower. if you want originality, spend the money, else do nothing.
Old May 27, 2014 | 10:21 AM
daanbc's Avatar
daanbc
St. Jude Donor '12
L82's had a dual snorkel. L48 had one. Look around you will find them cheaper.
Old May 27, 2014 | 10:24 AM
qwank's Avatar
qwank
they only went to snorkels to keep the sound level of the intake down. the cold air stuff was added in later years to get back some of the lost power. either use the whole setup, or an open style air cleaner.
Old May 27, 2014 | 10:26 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
There are several on the used market for less and you can still get the flex ducting from many vendors. I like the idea of having cool air ducted to my carb (I have an 80) and it seems to help a little overall after using it and then trying a 14" open element type, especially on a hot day around town. The L-82 dual duct system will retro-fit to your L-48.
Old May 27, 2014 | 10:34 AM
80Baby's Avatar
80Baby
I searched for an after-market cold air intake to fit my '80, but came up empty. Talking to some of the guys here... bottom line is the original dual snorkel set-up is the best one that will fit under the Corvette hood. The difference in performance between an open 360 air filter sucking hot air inside the engine compartment and the dual snorkel cold air intake is negligible ay best. But I'd venture a guess that the dual snorkel is slightly better, that's one of the reasons why Chevrolet went to it. It does help. I had a 360 air filter in my car when I bought it, I've since replaced it with the original factory set-up.
Old May 27, 2014 | 10:43 AM
Bloodzone's Avatar
Bloodzone
[IMG][/IMG]
I think I'll get a regular filter and maybe replace the snorkels later. As you can see from the pict my airflow as got to be decreased.
Old May 27, 2014 | 11:19 AM
Mike Ward's Avatar
Mike Ward
I think you're making a lot of incorrect assumptions. The stock housing provides more than enough airflow.
Old May 27, 2014 | 11:22 AM
Easy Mike's Avatar
Easy Mike
FWIW: looks like you're missing the plastic air box in front of the radiator.
Old May 27, 2014 | 11:28 AM
Bloodzone's Avatar
Bloodzone
If what I have is fine thats great I'll just stick with it. Only thing I was concerned about is airflow. Thanks everyone.
Old May 27, 2014 | 12:13 PM
CaseyJones's Avatar
CaseyJones
Plus, being the idiot that I am sometimes, I forget that both the L-48 and L-82 used the dual snorkle/ducted setup in 1980. Duh... My L-48 came with it.
Old May 28, 2014 | 10:57 AM
7T1vette's Avatar
7T1vette
You don't NEED the ducts. Leave it 'as-is'.
To Missing Snorkels
