Oil
Old May 31, 2014 | 07:01 PM
red topless gator's Avatar
red topless gator
Default Oil
Whats the best recommendation for oil in a 74 L48 with 7,000 original miles? I was leaning towards 20w50. Any thoughts?
Old May 31, 2014 | 09:38 PM
7T1vette's Avatar
7T1vette
You will get a million responses from a million different people. Suffice it to say that you can't go wrong with whatever the owner's manual (or Chevrolet Chassis Service Manual for 1974) specifies.
Many will say that you need to use an oil with added zinc or a zinc additive, to limit "possible" wear on flat-tappet/cam surfaces. With the lightly loaded valve train of a stock '74 engine, I doubt that is necessary...unless you are in the business of pulling tree stumps out with your Corvette.
IMO, you do NOT want (or need) to use a heavier weight oil that GM specified for that car. It would only serve to add drag to engine operation (which is wasted work) and cause increased heat and fuel use for absolutely no benefit.
10W30 organic oil or full synthetic oil would be more appropriate for an old engine with few miles on it, I think. If you are concerned about putting synthetic oil in your engine (for whatever reason), don't do it.
Old May 31, 2014 | 10:16 PM
cagotzmann's Avatar
cagotzmann
78 L48 177k KM's (110k Miles)
I have been using Mobil 1 15W50 but this is very thick on cold startup's. I am now using
http://www.amsoil.com/shop/by-produc...tic-motor-oil/
Nice 10w30 oil.
Easy on startup's, great wear protection and my engine saw a 3% increase in gas mileage. Engine also run's quieter on cold startup's.
Our local NAPA stores now carry the complete line of Amsoil Products.
Old May 31, 2014 | 10:30 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I'm a rookie, but I would NOT use 50wt oil...it is much to "thick" to be used in a low mileage engine.
My SBC 350 cu. in. has 212,000 miles on it, and I have just started to put 10w-40 in the engine because now it uses a quart of oil every 4,000 miles.
Old Jun 1, 2014 | 12:22 AM
illenema's Avatar
illenema
The newer oils are formulated for newer cars.
Why not use a oil thats specifically formulated for our older engines?
Amsoil zrod= good stuff. I like this oil as well http://www.schaefferoil.com/supreme-...acing-oil.html
Old Jun 1, 2014 | 12:22 PM
standswithabeer's Avatar
standswithabeer
Default oil
have done a ton of reading and decided on mobil 1 synthetic 15w-50. formulated for flat tappet engines, here's a link to their product line:
http://www.mobiloil.com/USA-English/...duct_Guide.pdf
1979 C3, 52K miles, stock engine, L48 with auto. will run approx 3-4K miles annually, oil/filter changed in the fall.
Old Jun 1, 2014 | 01:06 PM
vettebuyer6369's Avatar
vettebuyer6369
26,000+ hits on this endless argument in C3 Tech...
http://forums.corvetteforum.com/c3-t...test-data.html
Old Jun 1, 2014 | 08:29 PM
persuader's Avatar
persuader
Joe Gibbs HR-2 10W-30
To Oil
