painted wheels
Old Jun 3, 2014 | 11:42 AM
hardlanding's Avatar
hardlanding
Default painted wheels
so my 80 is getting painted, and the owner of the body shop suggested i remove the paint from the wheels and polish them....it is a pretty much bone stock L-82 with 60K...is this a bad idea?
Old Jun 3, 2014 | 11:57 AM
qwank's Avatar
qwank
If they are aluminum I would polish them but clearcoat them again after
Old Jun 3, 2014 | 12:10 PM
Lakeside49's Avatar
Lakeside49
Remove the old, yellowed.clear-coat. I used CitrusStrip from The Home Depot, rinsing/plastic brushing after sitting harmlessly over night. polish them almost to a chrome-luster per my earlier post. You will not regret the effort for one minute.
The reviews are mixed about re- clear coating.
Old Jun 3, 2014 | 12:40 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You've lost me. Has a PO painted your aluminum wheels?
Old Jun 3, 2014 | 12:48 PM
Lakeside49's Avatar
Lakeside49
The aluminum wheels came clear-coated from the factory per the owner's manual and experience with the '82, all-original time capsule C3 that I bought.
Btw, I'm only referring to the OEM alloy wheels, as I can't be certain with this cell phone (can't see photo details in bright sunlight which we're finally getting today) whether the original poster is referring to original wheels or aftermarket which is obviously anybody's guess.
Old Jun 3, 2014 | 01:07 PM
qwank's Avatar
qwank
pretty sure '80-'82 aluminum wheels came clear coated
Old Jun 3, 2014 | 01:37 PM
AirborneSilva's Avatar
AirborneSilva
If they do have clear coat then yes remove and polish, if they don't have clear coat then yes polish. I did mine and they look great! I don't know if my 76 had a clear coat but I used the citrus strip stuff on the centers (painted black), and had to do quite a bit of sanding due to MANY years of neglect. I also bought a metal polish kit from eastwood and went to town, spent about 4 hours per wheel, well worth the time
Old Jun 3, 2014 | 03:13 PM
Easy Mike's Avatar
Easy Mike
I'm thinking 80-82 YJ8s were not clear coated. Earlier years were. The set on my 80 L-82 do not appear to be clear coated, but that doesn't mean one of the two POs didn't get there before me.
Check that. The Judging Guide very plainly says the 80-82 aluminum wheels had a protective clear coat on them. I've only read through the Judging Guide a couple of hundred times since I got it. You would think I would remember that little tidbit.
Old Jun 3, 2014 | 08:30 PM
hardlanding
These wheels appear to be painted a grey...there isnt a shinny chrome look to them
Old Jun 3, 2014 | 09:32 PM
qwank's Avatar
qwank
are they aluminum wheels or steel ralley wheels?
Old Jun 4, 2014 | 12:11 AM
Lakeside49's Avatar
Lakeside49
Let me further clear this up for you, without so much as the slightest shadow of the doubt, the `82's were clear-coated from Rockwell International. Again, I bought a car from the original owner who is a great guy but aside from changing the oil, never once so much as even oiled the door hinges or changed anything, let alone touch up the paint in 40,000 miles. The owners manual under "Cleaning Aluminum Wheels" also spells it out on pg. 4-4,paragraph 5, warning about what polishes to use soas not to damage the protective coating on the wheels - let me know if you would like me to scan and post it. Whoever gave you the impression that there was not 100% certainty that the aluminum wheels of this timeframe are clear coated did not know what they were talking about or their PO had removed it.
Old Jun 4, 2014 | 06:56 AM
hardlanding
Aluminum...and it is a 1980
Old Jun 4, 2014 | 12:56 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by Lakeside49
...Let me further clear this up for you, without so much as the slightest shadow of the doubt...
I'm not doubting you. All I said was I wasn't sure the 80-82 wheels were clear coated. I checked myself, corrected my mistake, and edited my post.
To painted wheels
