She's Dead, By Gum
Old Jun 9, 2014 | 10:40 AM
Stroh's Avatar
Stroh
Default She's Dead, By Gum
Dear Expert Panel,
I'm in need of a bit of assistance. My 75 ran fine the whole three times I've had time to enjoy her this summer... Then... Nothing. No power. Nada. I turn the key and there is only silence.
So I replaced the battery. I had a crappy 5oo cold cranking amp Walmart battery in it that she came with. I left it be, figuring don't fix it if it ain't broke. Well, it's "broke" now. So I threw a Diehard 725 cold cranker in there and... wait for... still nothing.
I checked my battery cables numerous times to insure a good connection. I checked grounds. No problem.
I tapped the old starter with a hammer a couple times, still NADA!
I'm figuring the starter's bad. A cheap fix, two bolts, the addition of a starter heat shield (I hear it's a good idea) and home free... Maybe.
But before I embark on a starter replacement, I thought I'd ask if it could be anything else, short of a MATRIX like EMP.
Old Jun 9, 2014 | 11:15 AM
F22's Avatar
F22
Originally Posted by Stroh
Dear Expert Panel,
I don't replace anything, until I know, to the best of my knowledge, what's going on. Didja check the fuses? The fusible link? Do you have a multimeter? Check voltages out at the solonoid. That'd be my first step.
Old Jun 9, 2014 | 11:24 AM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
Is anything else working? Lights? Radio? Brake Lights?
zwede's Avatar
zwede
You say there's "nothing", but I guess you're only talking about the starter? Lights, horn etc works?
First thing to check is the neutral safety switch.
Old Jun 9, 2014 | 11:33 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
O.K.
Rookie needs info....You can use a test light,,,but a voltmeter shows actual voltage....or even low voltage.....also--wiggle each connection while you are testing for voltage to make sure nothing is loose causing intermittent problems (ask me how I know....after a day of troubleshooting/thinking the problem "went away")
Do all the fuses test O.K. with the voltmeter?
Do the headlights shine brightly?
Do the blinkers work with the key "ON"?
Do the gauges operate with the key "ON"....engine "OFF"?
Does a voltmeter show 12V at the positive lug on the starter?
While you are under the car does the purple-(I think)- wire show 12V when a friend turns the key to the "ON" position?
Does the voltmeter show 12V at the positive lug on the back of the alternator?
If this needs to be checked ....
does the purple wire under the console show 12V where it connects to the safety switch (or where ever it is located) on the side of the shifter (my '68 model)....
does it show 12V in Park/Neutral on the connector wire that exits the safety switch?
Does the 12v drop off to Zero when the shifter is moved to reverse....and go to 12V when the shifter is in Park or neutral on the A/T.....................or Neutral on the M/T?
Get back to us when you check these things.
Old Jun 9, 2014 | 11:46 AM
Shark Racer's Avatar
Shark Racer
I have nothing further to add, other than to stress that zwede's first question is important. It's different to troubleshoot ABSOLUTELY no power vs no cranking.
Old Jun 9, 2014 | 12:31 PM
Crafty12's Avatar
Crafty12
Check the connection between the neg battery cable and the frame. It's right under the batt compartment on the cross member. That connection has "killed" many a Vett. The terminal gets dirty or corroded and kills EVERYTHING. Wire brush the connection and give it a try.
Old Jun 9, 2014 | 02:24 PM
Capkunu's Avatar
Capkunu
Bad, corroded - deteriorated grounds are Ye Olde Numero Uno electrical/starting issue.
Old Jun 9, 2014 | 02:38 PM
jeff06600's Avatar
jeff06600
Seat belt interlock? Didn't some early 75's have them?
Old Jun 10, 2014 | 07:48 AM
Stroh's Avatar
Stroh
Thanks for the comments fellas. Answer: She's dea, meaning no lights, no dash, no nothing, nada.
I will check fuses when I get home this afternoon. I have previously replaced the neutral safety switch (2 years ago) and everything worked fine three weeks ago. Started right up. No problems. I'm lost on her.
Part of the problem, of course, is that I have very little time until the weekend to run through diagnostics of anykind. I do have a voltmeter. I just can't figure how with good connections and a brand new battery I'm getting absolutely no juice to anything. I must be missing something.
As always, thanks for the time and the expertise.
Old Jun 10, 2014 | 07:49 AM
Stroh's Avatar
Stroh
First thing I'll check when I get home is the battery ground to frame. (AGAIN) Thanks guys.
Old Jun 10, 2014 | 07:54 AM
minitech's Avatar
minitech
Fusable link is my vote!
Old Jun 10, 2014 | 07:55 AM
F22's Avatar
F22
You check continuity on connections and wires with the ohm meter. Door Gunner's post is packed with good info as well. So this weekend, you've got some work ahead of you. Good Luck!
Old Jun 10, 2014 | 08:27 AM
harris1507's Avatar
harris1507
You can check for power at the Starter positive side, if no power it could be one of 2 things. Bad ground right under the battery box to frame, or the fuseable link near the starter. Good luck keep us posted
Old Jun 10, 2014 | 03:48 PM
dochorsepower's Avatar
dochorsepower
Similar happened to mine a few weeks ago. It was the main power feed that goes across the firewall, it had worn through the insulation and then blew the fusible link. Repair: replace fusible link and then wrap worn wiring to insulate.
To She's Dead, By Gum
