Cannot completely remove Power Window motor.
Hi there -
I'm trying to remove and replace my PW motor.
The window has been stuck in the up position.
I used a soft rubber clamp on each end of the window to keep/brace the window up.
I removed the 3 bolts and the motor is flopping around, but its pinion gear is hung up on the regulator (maybe 1/4") and won't clear. Please see pic.
Is there a way or trick to wiggle worm the motor to clear this obstacle? - or did I miss a step? Any help would be appreciated.
