1969 Corvette - Ignition switch
Old Jun 17, 2014 | 12:56 PM
edfrye's Avatar
edfrye
Default 1969 Corvette - Ignition switch
With ignition key switch set to "on" the battery current is approx 13-14 amps. Is this correct? Thanks Ed frye
Old Jun 17, 2014 | 02:05 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
wild guess ..... you mean Volts instead of "amps" ?
Yes a fully charged battery should show app. 14 volts.
Old Jun 17, 2014 | 06:54 PM
edfrye's Avatar
edfrye
No, I mean amps. I'm guessing there are some circuits that are active automatically. Thanks Ed
Old Jun 19, 2014 | 02:07 PM
edfrye's Avatar
edfrye
Battery current readings:
IGN sw OFF or ACC = 0.02 amps
IGN sw ON = 12.3 amps (nothing else on)
Additional Info:
Parking/running lights ON = 5.66 amps
Headlights Low Beam ON = 13 amps
Is the IGN sw ON current normal for this vehicle ?
If not, any suggestions on trouble shooting this problem would be appreciated.
Thanks, ED
Old Jun 19, 2014 | 08:49 PM
Sayfoo's Avatar
Sayfoo
Ignition on, engine running or not?
This may be a normal value when running, but i can't say for sure. If not running, then you are bleeding to ground someplace.
What kind of ignition do you have? Stock points?
There is (stock) a resistance wire in series going to the coil.
Electric fuel pump?
Start pulling fuses to see where to start.
I remember back in the day, it was said to always put the key in the acc position when the engine was off and you were just sitting and using the radio, because, in the on/run position you could have current flow through the points if they closed.
Old Jun 19, 2014 | 08:57 PM
billcarson's Avatar
billcarson
possible defect in choke heater causing an additional draw?or partially shorted choke wire to heater.mine was melted to the intake manifold.
Old Jun 19, 2014 | 10:09 PM
Stick To Your Guns's Avatar
Stick To Your Guns
To 1969 Corvette - Ignition switch
