Wire question????
Old Jun 21, 2014 | 11:59 AM
freddy4099's Avatar
freddy4099
Default Wire question????
Looking to find out if someone could tell me what color wire and where that wire comes from for this piece on the front left of engine by the carberator, just under the air cleaner? I don't have any loose wires there. Also what is this for? Thanks in advance. Trying to post a pic and having problems.
Old Jun 21, 2014 | 12:09 PM
Carl Granquist's Avatar
Carl Granquist
Photos, plus a little background info in your profile will help us answer your question.
Old Jun 21, 2014 | 12:21 PM
freddy4099's Avatar
freddy4099
Default picture
this is the picture, it is from a 1979 with cruise. thanks and I will fix my background.
Old Jun 21, 2014 | 12:29 PM
jnb5101's Avatar
jnb5101
That's an Idle Solenoid used to add more throttle at idle when there is an extra load (as an A/C compressor) is engaged.
Old Jun 21, 2014 | 12:33 PM
freddy4099's Avatar
freddy4099
Default wire?
Any Idea what color the wire that plugs in to the idle Solenoid would be and where it would come from?
Old Jun 21, 2014 | 01:31 PM
jnb5101's Avatar
jnb5101
On a 72 an 18 gauge Tan wire that ties into the TCS connection. From there it goes thru the fuse panel to the TCS Delay Relay.
Old Jun 21, 2014 | 01:42 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
On a 79 it's a green wire that snakes across the top of the intake manifold in front of the carb and enters the ac harness near the compressor.
See the green wire kinda below the AIR pump?
Old Jun 21, 2014 | 02:55 PM
freddy4099's Avatar
freddy4099
Default Thanks
Yep that was the right wire, next to a light blue wire. Even had the correct connector on it. Thanks all.
To Wire question????
