Need help please, Rochester jet settings ?????
Old Jun 26, 2014 | 11:43 AM
oldsarge's Avatar
oldsarge
Default Need help please, Rochester jet settings ?????
I have a 73 454 with 400 turbo tranny with a/c. What would be the setting for a Quadrajet. There are two jets, I believe, which I am not sure which is which. Could someone please let me know, what the settings would be for each and which one is which. Thank you.
Old Jun 26, 2014 | 03:10 PM
Camivette's Avatar
Camivette
Carb # Application Main Jet Main Rod Spring Sec. Rod Jet Area Jet Area
7043212 CHEV 73 Vette Hi Perf. Auto 74 44 7036019 DA 2.7803 3.7699
Old Jun 26, 2014 | 03:11 PM
Camivette's Avatar
Camivette
Per Lars carb listing paper
Old Jun 26, 2014 | 07:17 PM
oldsarge's Avatar
oldsarge
I have no idea what that means. I thought it was like so many turns, like 1 1/4 or something. How do you get Lars papers ? and will I be able to understand ???
Old Jun 26, 2014 | 08:27 PM
Shark Racer's Avatar
Shark Racer
Be careful throwing random jets and rods at a carburetor. First off, you need to match the jet to the casting number, ASSUMING the carburetor hasn't been tweaked.
If its been tweaked, all bets are off.
In carburetor speak, a jet is an orifice with conical inlet and outlet that measures a metered amount of fuel. Larger jets richen the mixture, smaller lean. Rods are the opposite as they restrict fuel flow through the jets.
HTH.
Old Jun 26, 2014 | 09:48 PM
Mooser's Avatar
Mooser
I'm thinking maybe you mean the mixture screws at the front?
Anyway, email Lars for all your Q-jet info
v8fastcars@msn.com
HIH
M
Old Jun 27, 2014 | 12:12 AM
donbayers's Avatar
donbayers
Lars is awesome. He sent me Q-jet tuning document. Everything you need to know.
Better yet if you got problems or unknowns. Send it to him to match up with your engine I.e. Check everything out spec wise
Old Jun 27, 2014 | 10:06 AM
oldsarge's Avatar
oldsarge
v8fastcars@msn.com
HIH
M
Yes, sorry, that is what I meant, the mixture screws. This carb had been rebuilt when I got it, but the mixture screws are closed.
Old Jun 27, 2014 | 09:42 PM
MelWff's Avatar
MelWff
turn them out about 2 full turns from fully seated and then set the idle speed screw on the side of the carburetor to your desired speed. Then starting with either mixturen screw turn it in 1/4 turn at a time till you notice an rpm drop when you get a drop go back out 1/4 turn. Then do the same with the other screw.
Old Jun 28, 2014 | 08:31 AM
jnb5101's Avatar
jnb5101
The idle screws are closed? Did the engine run with this setting? If it did, the carb "rebuild" is highly suspicious. BTW, Lars recommends 74-41 jet/rod values for BBC with CH secondary rods. I can attest that these numbers work very well.
Old Jun 29, 2014 | 01:55 PM
oldsarge's Avatar
oldsarge
There is no gas getting into the carb. All I did was switch the two carbs, The first carb was working fine, but I wanted to switch, just for the numbers thing. I don't understand why no gas is getting into the carb. I have adjusted the mixture screws as posted, but still no gas.
Old Jun 29, 2014 | 02:24 PM
Mooser's Avatar
Mooser
I've only stumbled my way through my own carb a few years back (with help from Lars and a book by Cliff R which only showed up afterwards...) but here's maybe a starting point
If the float is stuck (or the little plunger fuel valve disconnected inside it won't let any fuel into the carb) since it would think the bowl is already full.
Also, If it's got one of those paper filters with the anti-drain back rubber flap bit and it's in backwards somehow.........
Anyway, I'm sure someone who actually knows something will be along shortly
M
Old Jul 1, 2014 | 12:00 PM
oldsarge's Avatar
oldsarge
Additional info, please see post #11
Old Jul 1, 2014 | 12:56 PM
Camivette's Avatar
Camivette
I apologize if I'm going to seem to oversimplify.
On the idle screws, close them, clockwise, until they just seat and the open the 1 to 1 1/2 turns each to get started.
I'll assume there is fuel in the tank and the pump is operating since it did before....at least for now
Add fuel through the vent at the top of the carb. You need a really small funnel or be creative. Don't know how much but maybe 1/4 cup or so?
Activate the throttle and see if you get fuel. Maybe the carb is just not getting a prime to it. If you see fuel, try to start and we'll go from there
Old Jul 1, 2014 | 05:17 PM
jnb5101's Avatar
jnb5101
You guys from Canada are killing me with your avatars.
Old Jul 2, 2014 | 07:43 AM
joewill's Avatar
joewill
no gas to your carb has nothng to do with jet settings, or idle mixture screws.
check to see if you have gas in the line as you crank the engine ( gas hose in a jar as you crank). then see if you have gas in your float bowl ( fuel getting past the filter). check to see if your accelerator pump is working ( gas squirting in the carb as you pump the accelerator). if all this is true then you have gas to your carb. if not, then you have a basic problem long before you need to consider idle mixture and meter and rod sizes.
To Need help please, Rochester jet settings ?????
