C3 Certification Label Data
Old Jul 2, 2014 | 04:42 PM
Swiss1's Avatar
Swiss1
6th Gear
Default C3 Certification Label Data
Hi,
I need to reproduce the Certification Label on a 1973 C3. I see that the label is not really an issue to find, but how can I get the data for it (apart from the VIN, of course).
1973 CHEVROLET CORVETTE C3
VIN# 1Z67J3S421681
http://api.viglink.com/api/click?for...e%20Forum&txt=
Thanks!
Old Jul 2, 2014 | 04:57 PM
Mike Ward's Avatar
Mike Ward
You 'need' to replace it, or just 'want' to? If it's for judging, the repro labels are not quite right and will get a deduct in any case. Having the correct numbers won't help.
Unless you can find a car with the identical options as yours which still has the original label in place, it's anybody's guess what would be correct.
Old Jul 2, 2014 | 05:08 PM
Swiss1's Avatar
Swiss1
6th Gear
I exported the car to Switzerland and they (the DMV) are insisting it be on the car. I'm not sure if they compare the data to records (doubtful), but I would like not to mess it up...
So label accuracy is not for concourse presentation, but for the legal issue required (for some unknown reason) in Switzerland.
If someone has some kind of database, it would be great. Or even someone can translate what the data spec are? Even if someone has a picture of the label from a similar car and if there's a way to find the actual build date?
VIN# 1Z67J3S421681
Convertible, Auto Trans, 350 CI motor, A/C.
Any help would be greatly appreciated!
Old Jul 2, 2014 | 06:58 PM
Mike Ward's Avatar
Mike Ward
I was afraid that your answer might be that some bureaucratic agency might 'need' it. There is no publicly available database that I am aware of and I imagine that your authorities wouldn't have one either.
The data in the upper right corner is the month and year the car was built in.
GVWR = gross vehicle weight rating
GAWR = gross axle weight rating
frt= front axle
rear= rear axle
The following numbers are in pounds, (not kilos).
The car's build date (for registration purposes) can be found on the trim tag on the driver's side pillar post. It will be shown in the upper right corner of the tag as a single alpha charter followed by two digits. Your tag probably reads I27 which is April 27th 1973.
Old Jul 2, 2014 | 07:09 PM
oldsarge's Avatar
oldsarge
Do a search here in the C3 section, there has been a lot of threads on this issue with some examples. Here are a couple of examples, I think they were BB, but not sure what other options.
Old Jul 2, 2014 | 08:34 PM
dmaxx3500's Avatar
dmaxx3500
only problem is ,when you try to remove that blue tag,it will come-apart,unless somebody has any tricks?
Old Jul 2, 2014 | 11:25 PM
Swiss1's Avatar
Swiss1
6th Gear
No tag on the car... That's the problem
Looks like I have a build date of 4/27/1973
Will try and compare VINs.
Old Jul 2, 2014 | 11:29 PM
Swiss1's Avatar
Swiss1
6th Gear
The Blue one is close on the manufacture range, but does someone have an example with the following RPO?:
1YZ67 Base Corvette Convertible (190hp)
C60 Air Conditioning
J50 Power Brakes
M40 Turbo Hydra-Matic Automatic Transmission
N37 Tilt-Telescopic Steering Column
N40 Power Steering
Old Jul 2, 2014 | 11:30 PM
Swiss1's Avatar
Swiss1
6th Gear
Thanks for the detailed information! I will keep searching an hopefully someone recognizes the spec.
Old Jul 3, 2014 | 01:39 PM
Swiss1's Avatar
Swiss1
6th Gear
LOOK WHAT I FOUND!!
http://www.gmheritagecenter.com/docs...t-Corvette.pdf
You can change the year on the URL and get quite a few years.
A wealth of data!
To C3 Certification Label Data
