Front end Suspension
Old Jul 9, 2014 | 07:32 PM
mk8035's Avatar
mk8035
Default Front end Suspension
I have a 76 Vette that had a 350 engine in it. I have the engine removed and i am replacing it with a 454. The question is that the Front end Suspension has never been replaced and i would like to upgrade it while the engine is out also maybe the steering also. Any suggestions on any kits that are out there that you guys have tried or know works for my application?
Old Jul 10, 2014 | 02:03 PM
MelWff's Avatar
MelWff
look at the kits from vette brake products as an example
Old Jul 11, 2014 | 06:06 AM
Cavu2u's Avatar
Cavu2u
VBP stuff is tried, tested, and true.
Old Jul 15, 2014 | 09:18 PM
auavette's Avatar
auavette
I did replace on my 76 the 406 for a 496 with a 8-71 blower.
Used VBP front suspension with mono leaf spring and replaced the steering with a steeroids rack and pinion.
Works excellent.
Old Jul 15, 2014 | 09:31 PM
Lupigiato's Avatar
Lupigiato
Old Jul 15, 2014 | 11:39 PM
68/70Vette's Avatar
68/70Vette
If your budget will allow it, buy aluminum cylinder heads for the 454. Aluminum heads, aluminum water pump, and aluminum intake manifold you can get down close to the weight of a small block in the front end of the car.
Old Jul 16, 2014 | 06:59 AM
mk8035's Avatar
mk8035
Well on the engine i am going to buy a crate engine. Thanks for the info.
To Front end Suspension
