Ocala Fl HELP!!!!!
Old Jul 16, 2014 | 06:28 PM
V4motorsports's Avatar
V4motorsports
Default Ocala Fl HELP!!!!!
I bought a 71 Corvette today in Tampa. Almost immediately, the car developed a miss. Cruising at 60-70 mph, it was missing (skipping) terribly. I made it to a garage and the mechanic took it for a ride with me. He suggested that I change the wires and spark plugs. We found that a couple of wires were crossed and it seemed to idle better.
We took it out for a test drive and the skip is still there. I'm trying to get the car back to CT. by the end of the weekend.
Is there anyone in the area that may be able to take a look at it for me or recommend someone I can take it to. I have no tools.
I was thinking that the timing may be off. The garage I took it to didn't have a tack/dwell or timing light.
HELP!!!!!!!!!!!!!!!
Russ
Old Jul 17, 2014 | 10:42 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
If it has the points-type distributor....buy a set of points/condenser/cap/rotor/a Philips and a Common screwdriver.....
then change the parts yourself.
If it is HEI distributor.....change the dist. cap and rotor......
Those are two quick fixes for under $50 that could solve the problem...(and probably needed to be done anyway)
Keep us updated.
Old Jul 17, 2014 | 01:00 PM
Roma's Avatar
Roma
Try to contact heckler65 here on the forum. As far as I remeber he lives in Ocala and could help you
Old Jul 17, 2014 | 03:40 PM
V4motorsports
Thanks guys,
Took the car to Burnyzz Speed Shop and found out it was a fuel problem. Gas tank, filter were full of crap. They drained, flushed and sealed the gas tank and blew out the fuel lines.
Now they are having a problem with the carburetor. Keeps flooding itself out. They are going to replace it.
Maybe on the road again tomorrow.
Russ
Old Jul 17, 2014 | 08:00 PM
imariver's Avatar
imariver
Good luck with that, hope everything works out for you.
Old Jul 17, 2014 | 08:10 PM
Brandons72vette's Avatar
Brandons72vette
on the new '71, but sorry to hear you are having issues. Best of luck!
Old Jul 17, 2014 | 08:16 PM
69Pman's Avatar
69Pman
Not sure if you got yours from a dealer or not but if so, I've noticed that a ton of them will leave just enough gas in the tank to start up and load on a trailer when necessary. Got our '69 from a dealer and there was actually water in the tank, you could literally see a small amount inside after removing the filler cap. Brought it home without inspecting it that far (nooby move) and I drive it around the neighborhood only to have it sputter in and out of life and eventually it stalled numerous times before I got it back to the garage. Filled the tank full, flushed out the tank with an additive that helps with the moisture, and drove out the rest of the "bad" fuel. She runs like a champ now. Just sucks having to learn the hard way. If only you could have seen the look on my face as the car was now ours, including any of its problems.
Old Jul 17, 2014 | 08:17 PM
V4motorsports
Here she is, waiting for the tow:
Russ
Old Jul 17, 2014 | 08:21 PM
Brandons72vette
Russ
Man it looks great! This will pass, and you will soon be back on the road.
69Pman's Avatar
69Pman
Good looking '71, none the less.
Old Jul 18, 2014 | 07:00 AM
V4motorsports
I bought it from a private seller. The car rides great, even the AC works! Like all old cars, there are things that need to be done to it and I went in anticipating that.
It's just frustrating that when you ask for something simple (having the car serviced) after informing the PO that I would be attempting to drive the car back to CT, that it wasn't done.
I know the look on your face, it was on mine also but you really didn't want to hear what I had to say after it broke down!
Hopefully, it will be as good as new and I won't have any other problems the rest of the way.
Russ
Old Jul 18, 2014 | 07:01 AM
V4motorsports
Thanks!
Rides great! Looking forward to many more miles and getting her home.
Russ
To Ocala Fl HELP!!!!!
