so here we go trying to unf%$k another bubba move. My 76 has a multi lift rear spring that's 2.25 wide that's correct right??
yeah that's what I thought. My bolts are 5/8 head or 7/16 bolts indicating that the spring should be 2.5 wide. That's probably why my spring has room to wiggle a bit fore and aft.
The rear sits high and handles like greased snot on a hot day to bring the rear back down to Earth and get it to handle better what would be the best way to go for a rear spring?
Replace it with a monoleaf composite spring. Just get one with the load rating that will be best for the way you will be using the car. You might also want to put a decent set of shocks on at the same time, if they have some years on them.
This is probably the best route .
C3 on the whole were treated like little red headed step children.
Passed from one owner to next ...each had a dream to own a corvette and no money to maintain it right.....they were neglected .
So most went to hell ....needing everything today
If your going to keep it and enjoy the true handling and driving fun it can provide , you ll need to spend to fix what should have been done faithfully years ago.
thanks for the replies so far. I have my second thoughts on the mono spring....mainly losing the ballast weight from the back end.
If I did go with the Mono spring I have KYB shocks that I hope to use but I have heard they will not control the bounce. From what I have read 360# is what I would want for a spring?
my expectations are a decent ride, stock or just a little lower ride height. this is just a driver so I can live with it being a little on the stiff side
the correct diff cover with the correct bolts and correct bottom plate would also cure your problem although I think a spring change might be easier but slightly more expensive
1) If your rear end is sitting too high and you want to lower it, most will use longer (8 to 10 inch) between the trailing arm and the ends of the spring.
2) If you go with a mono/fiberglass rear spring, KYB shocks (white, high pressure) WILL NOT make you happy. Been there, done that. I am currently using KYB GR2 shocks specially valved for mono springs. They work very well, but I don't want to start another 'which shock is best' flaming long thread.
3) Talk with VB&P about the spring they recommend - it is not always the stiff 360#. They recommend (usually) a 330# for small blocks not used on the track.
The rear spring is a 7 leaf unit that Bubba installed and the car sits real high. I tried the longer bolt Bubba fix but the spring ends rubbed the side walls and I didn't dare drive it.
Kyb white shocks are what I have good to know on that tip. I really don't have the extra money right now for the Bilstein shocks that everyone recommends.
it is a small block car just street driven with a stock 350.My 24 year old daughter drives it more than I do.
something is not correct about that spring or rear cover, the bolts should not be touching the tires. You started off saying you have four 7/16 bolts for the spring plate, they should be 9/16.
If you want a good ride but with decent control in turns, I think you might be better off with a lower # spring (330#, perhaps) and stiffer gas shocks (ie, Bilstein Sports) in the rear. A 360# spring may be a bit harsh and may cause the rear of the car to sit high (depends on the manufacturer and how they designed the spring).
Do some research on spring rate vs. ride height of various brand springs so that you know what you will end up with after the install.
My '73 SBC w/auto has a single composite leaf. The number I'm not sure of, as it came on the car when I bought it. Big block of wood in there to make it fit where the multi-layered stock leaf was sandwiched.
The shocks I can't ID either; they're yellow with bellows/boot on the bottom where they join up with the arm.
High speed cornering, like Interstate ramps with a 50 MPH limit; acts like it's rear end wants to intermittently drift outside the turn. And if I try to compensate, it can aggravate it! Best thing I've found is just let it go; it hasn't spun out (yet), as it does correct itself with patience. But should it really do it in the first place?
Steve
The problem you are having where the back end wants to intermittently steer could be warn parts but if it is not that it is your alignment. You may need more toe in. Should be 1/8 total toe.
Go with a composite spring from van steel or vette brakes and products.
Are you talking rear end toe-in? I know the shop did a front end alignment, and the car does point & drive very nicely on straightaways. The two large rear leaf bushings look like originals, so they are worn.
I swapped out these bushings.
Old ones were very worn.
New brake pads & shoes were also installed by the shop, but not sure if they aligned the rear. I've got some very old tires on the car too that are not helping matters.
Not trying to hijack here: Just mentioning that all these things do matter as well as main components, in rear end performance.
Yes also do not want to hijack this, but to quickly answer you question yes 1/8 in rear toe in. The problem that your having where you are experiencing the change in the rear that causes it to feel real lose is you are hinting a brake over point in the rear where one wheel is going toe out. a few things can cause this such is the toe setting but also warn bushings. The ones you need to really worry about are the trailing arm bushings. Also bad half shaft stub axles.
Another remedy would be to slide a bushing that has been cut to the correct length over each 7/16" diameter bolt in order to snug the spring-pack into place.
Of course this fix could be classified as "Bubba"......but certainly easier and much less costly than replacing many mis-matched parts.
