Seriously, it may be a weak ground one that side. If all of the bulbs are good and identical side to side, then, it is possible one of the ground circuits is loose. You can try using a length of heavy wire, tied to a known ground, and touch the ground of a few light sockets to see if the flashing rate changes.
If the fuse was bad, wouldn't the turn signals stop working?
Yes, they would.
Every time I've seen this happen, it was because of either a burnt out bulb or the circuit was overloaded, i.e plugging in trailer lights. In the case of overloaded, a heavy duty flasher always took care of that. For a few dollars I'd try that.
No I don't think so, the reverse light is not a blinking light.
But if you removed the reverse light and connected it to the signal circuit then that could be your problem.
Why remove the white reverse light?
Because it looks better with 4 red lights. If you do a search you will find a lot of people have done the conversion. Ecklers even sell a kit to do it.
Seriously? That wouldn't pass the state inspection here in Pa.
