How do-able is doing a repaint?
Old Jul 29, 2014 | 02:58 PM
Shdggsdv's Avatar
Shdggsdv
Default How do-able is doing a repaint?
Hey guys; I'm still shopping and the best cars (Solid body without cracks, little rust, new engine/auto trans) in my budget always seem to have paint chipping off and would require new paint.
So my question is; if time isn't much of a restraint and my maximum budget is $2,000, how difficult might it be for me to repaint the car with minimal help (My father has experience, but won't be around extremely often to help)? I don't want show quality, because I want to build the car into being my daily, so I don't really give a crap about the paint being perfect as long as it's glossy and looks nice on the road. So what do you guys think?
Old Jul 29, 2014 | 04:13 PM
Jbster's Avatar
Jbster
Do you have an air compressor big enough to paint with and a good paint gun and a booth or garage? I don't think $2k would cover the tools and the supplies to do a paint job.
Most people strip the car down to fiberglass with stripper or razor blades. Tedious and time consuming, but necessary if you don't want problems later.
Search for paint jobs on this forum and check out the paint/body section under general corvette topics.
When the time comes (when I have everything else fixed), I will be painting my car and doing all the work myself. No way am I spending 10 to 20k for a paint job.
Good luck.
Old Jul 29, 2014 | 05:06 PM
persuader's Avatar
persuader
Here we go again!
Mashman's Avatar
Mashman
You can do it. Look at the TCPGlobal single stage urethane. I think as a beginner, it would be the easiest to get a decent job done.
Old Jul 29, 2014 | 05:10 PM
Roadster71's Avatar
Roadster71
I think it is doable for 2k if you supply all the labour. Spraying the car is the easy part. The preperation is where all the labour/cost is. Did my 71 myself.
Old Jul 29, 2014 | 05:16 PM
Tim81's Avatar
Tim81
Like others have said, check out the paint and body forum. I started my own paint job just over a year ago and will probably have it completed this October. It is very time consuming and laborous. I am not using the best of everything and when finished I'll be under $2000 dollars for the whole job.
Good Luck Tim
Old Jul 29, 2014 | 05:18 PM
terry82's Avatar
terry82
yes this has been talked about and talked about and http://forums.corvetteforum.com/c3-g...ar-myself.html
Old Jul 29, 2014 | 05:30 PM
oldgto's Avatar
oldgto
Originally Posted by Roadster71
Did my 71 myself.
So did I. Wife & I did all the prep, sanding, & primer. A friend of mine shot the paint... PPG single stage acrylic urethane (Steel Cities Gray).... not bad for an $800 paint job!
Old Jul 29, 2014 | 05:36 PM
John 65's Avatar
John 65
The answer is yes..if you have the equipment, time, room, and patience. I used all Dupont chemicals and was very happy with the results on 2 Vettes sprayed here at home.
Forget about the not caring if its not perfect. For the amount of hours it takes to actually prep these cars, you don't want to settle for anything less, or have to repair it in the near future. One panel at a time, it's a lot of work but very rewarding. Good luck.
Old Jul 29, 2014 | 05:50 PM
oldgto's Avatar
oldgto
Originally Posted by John 65
The answer is yes..if you have the equipment, time, room, and patience......
Forget about the not caring if its not perfect. For the amount of hours it takes to actually prep these cars, you don't want to settle for anything less..... it's a lot of work but very rewarding.
Yup.... took us about a year.
Old Jul 29, 2014 | 08:25 PM
Cavu2u's Avatar
Cavu2u
Originally Posted by persuader
Here we go again!
What we mean is......there are many threads here stating the costs of painting these cars. Kinda the same answers all over again. The Search feature isn't perfect, but it will get you in the ballpark.
Yes, $2K is doable.
Steve
Old Jul 29, 2014 | 09:45 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
Did my 71 myself.
So did I, less than 2k for me also. It's surely not perfect, but 10k for paint was out of the question for me.
Just remember, when you are sick and tired of sanding, you're half way there.
Old Jul 29, 2014 | 10:32 PM
Shovels and Vettes's Avatar
Shovels and Vettes
If you pay over $2000 somebody is ripping you off.
Old Jul 30, 2014 | 02:16 AM
persuader's Avatar
persuader
Yes, $2K is doable.
Steve
Yeah! What he said.
If you do most if not all the work, It can be done.
Old Jul 30, 2014 | 11:18 AM
Bagpype's Avatar
Bagpype
You obviously have never sanded, prepped, high build primed, sprayed a guide coat, block sanded, another high build primer coat, another guide coat, more block sanding, filled, more high build primer, blocked, da sanded, regular primer, taped, and cut. All that before you paint. And have I mentioned the raw cost of decent paint? Not cheap. Primer? Not cheap. Sand paper, tack cloth, tape, paper? Not cheap. Not to mention, painting is a skill and an art in and of itself. I wouldn't pay someone 2000 either cause I'd get my car back looking worse than it did when it went in!
Old Jul 30, 2014 | 01:00 PM
929nitro's Avatar
929nitro
Just one gallon of primer, base and clear and the activators for these is going to run me about $1250. Does not count sand paper fiberglass, resin and hundreds of hours in labor. Doing the work myself I see why the pros charge the prices they do, can't afford it but I completely understand.
And to the original post yes you can do it if you take your time and have the equipment, some of which you can rent.
Old Jul 30, 2014 | 01:01 PM
Priya's Avatar
Priya
Iwasmenowhesgone was being sarcastic.
To How do-able is doing a repaint?
Old Jul 30, 2014 | 01:06 PM
Priya's Avatar
Priya
Spraying the car is the easy part if you have experience spraying and a proper spray booth. If its your first time you will almost certainly make a mess of it. I do all the prep work and then pay someone with experience to actually hold the gun and spray.
Old Jul 30, 2014 | 01:08 PM
Priya's Avatar
Priya
Best advice yet.
Old Jul 30, 2014 | 02:07 PM
Priya's Avatar
Priya
If the OP wants a wide range of opinions he/she can find it here:
http://forums.corvetteforum.com/c3-t...ob-prices.html
