Stripped sill holes
Old Jul 29, 2014 | 10:54 PM
MMJ's Avatar
MMJ
Default Stripped sill holes
Finally got my carpet installed and am starting to reinstall trim. When I started to reinstall the door sill plates, I found out all the screw holes were stripped out. What's the best way to fix this? Fill them with something like jb weld and retap them? Thanks for the help.
Mark
Old Jul 29, 2014 | 11:05 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
Welcome to the club, i used some clear silicone on the threads to keep them from rattling.
Thats all i got
Old Jul 29, 2014 | 11:18 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
I'll take some flack for this but what I did was use some of the yellow plastic mollies that you usually stick into drywall. Stuck them in the hole, ran the screws in, tight ever since. Guess I'm Bubba!
Old Jul 29, 2014 | 11:20 PM
vbgod1's Avatar
vbgod1
If you can't find a little larger screw, metric maybe, what about trying one of those drywall anchors? Or put a small piece of (copper/solder) wire in the hole and use the screw that goes in there?
Old Jul 29, 2014 | 11:42 PM
Kid Vette's Avatar
Kid Vette
CORVETTE CENTRAL MOUNT HOLE REPAIR KIT PN 131125
Old Jul 30, 2014 | 12:47 AM
F22's Avatar
F22
Yep, cut to length, insert and you're good to go. I used thes on the numerous stripped holes in the dash pieces as well. The hardware store also sells the drywall anchors in kits, that come in various sizes, besides yellow.
Old Jul 30, 2014 | 02:36 AM
TurboStitchCW's Avatar
TurboStitchCW
I did that with my side mirrors....used the white ones
Old Jul 30, 2014 | 05:17 AM
Haggisbash's Avatar
Haggisbash
I used stainless steel rivnuts and epoxy glued them into the stripped out holes rather than install them with the tool. Used stainless steel cap screws with a bevelled head to hold the trim in place. Looks good, not NCRS but better than the rust prone std screws (I hate self tapping screws on a car so avoid using them wherever I can). Factory liked them they were cheap:-)
Old Jul 30, 2014 | 06:17 AM
Garys 68's Avatar
Garys 68
Yep, plastic drywall anchors, they work great.
Old Jul 30, 2014 | 07:31 AM
MMJ's Avatar
MMJ
Thanks, guys, great ideas!
Old Jul 30, 2014 | 08:37 AM
redrdstr72's Avatar
redrdstr72
FWIW, I've found success when trying to put a screw into a soft piece of trim by first putting a small piece of heat shrink tubing over the threads of the screw, then heat it to shrink into place. My logic was that I'm only adding to the soft trim so it should not be a problem.
I'm not sure how well this would work when going into something hard like the sills, but I would definitely try this method before drilling into the car.
Hope this helps...
Old Jul 30, 2014 | 08:52 AM
7T1vette's Avatar
7T1vette
The plastic drywall screw inserts will work. I prefer to fill the hole with JB Weld stick-type [putty] epoxy; let harden; drill for screw size; tighten snugly...but not 'tight'. This works well with interior screws and parts.
Old Jul 30, 2014 | 10:05 AM
bashcraft's Avatar
bashcraft
If you're going to do it, do it right.
http://www.harborfreight.com/45-piec...-kit-1210.html
Old Jul 30, 2014 | 10:27 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The three I'm using happen to be blue.
Old Jul 30, 2014 | 11:16 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Set the Mig on lowest setting....weld holes closed/grind smooth/re-drill to proper size.....
OR
Install Rivet-nuts (crimp them tightly to keep them from loosening---use matching machine thread screws to avoid stripping in future)
OR
Use the Blue ones that M.W. uses!
Old Jul 30, 2014 | 06:37 PM
flyeri's Avatar
flyeri
I used the rivnuts but if I were doing it again I would use rubber well nuts. No rivnut tool needed, just a drill. I found them at a local hardware store. Google well nut if not familiar.
Old Jul 30, 2014 | 07:31 PM
LT-1 kid's Avatar
LT-1 kid
plastic anchors are the best sulution, its easy and works the best
To Stripped sill holes
Old Aug 10, 2014 | 11:23 PM
Darrell's 68's Avatar
Darrell's 68
Exactly what I used too. Has worked great.
Old Aug 11, 2014 | 12:09 AM
orourke's Avatar
orourke
May not be high tech but stick a piece of .032 safety wire shaped like an "L' in to the hole. The "L" shape will keep the wire from falling into the oversized hole. The screw will tighten up just fine. You can go up a size if you need too. Work's fine for reamed out interior panel holes too.
Old Aug 11, 2014 | 01:20 AM
Kim72's Avatar
Kim72
Exactly what I have done and it works great.
