Differential Plug Tool
Aug 6, 2014 | 06:46 AM
I'm looking for the GM plug tool for removing & installing that rear end plug. The open square socket. My plug is in there super tight because of a previous overzealous owner/mechanic, and it seems nothing I have fits the plug well enough for the torque required to remove it.
Does anyone here know where this tool can be obtained?
Thanks in advance.
Steve
Aug 6, 2014 | 07:10 AM
IIRC all you should need is a 5/8 square (8 point style) socket.
Check someplace that deals with machinery / farm / tractor type stuff, should be semi common
M
Aug 6, 2014 | 07:23 AM
Also, if you do find one, look at it carefully and make sure its a double square and not some torx looking thing.
Sears should also carry it down there.
M
Aug 6, 2014 | 07:57 AM
2016 C3 of Year Finalist
72
I agree with the 8 point 1/2" socket. I had to buy mine online. It came from Armstrong tools, I believe
Aug 6, 2014 | 08:09 AM
Quote:
Originally Posted by
Mooser
M
I got mine on Amazon and it worked great.
Fran
Aug 6, 2014 | 08:45 AM
Like this?
Aug 6, 2014 | 08:46 AM
Looks like it's the right critter
M
Aug 6, 2014 | 08:52 AM
A crow's foot works well too!
Aug 6, 2014 | 09:09 AM
Bigass crescent wrench.
Carter
Aug 6, 2014 | 10:59 AM
Mooser
M
That is correct. Not 6 or 12 but
eight -sided. Tool companies carry it.
A breaker bar always helps.
Aug 6, 2014 | 12:22 PM
71scgc
Carter
I tried the big crescent trip;
Too big to get on it and turn, as it's a tight area.
A smaller crescent isn't enough to loosen the mf'er. (No...the guy who last tightened it in there is the mf'er!)
Aug 6, 2014 | 12:55 PM
Cavu2u
Place a bar or wrench over small crescent wrench to extend leverege.
Aug 6, 2014 | 01:04 PM
Hit it with some lube like PB Blaster. They can be rusted in place pretty good.
On my RX7 I gave up and took it in and they needed a 4 foot bar to break the plug free.
Aug 6, 2014 | 07:03 PM
Technically 12 points work on square heads, that's how I got mine out. Might not be the greatest idea if it's really in there, though.
Aug 6, 2014 | 07:33 PM
Cavu2u
An exercise in futility. No crescent wrench should go near a Corvette. Get the proper socket or butcher it off and put a new one on.
Aug 6, 2014 | 08:47 PM
widowmaker221
I don't have a lift Widowmaker, so room to apply a lever is nonexistent. A socket, on a long long extension so the lever can be outside the wheel well, is the only option I have here at home.
Aug 6, 2014 | 08:48 PM
paul 74
I like your thinking Paul.
Aug 6, 2014 | 09:30 PM
paul 74
Oh come on Paul, "any tool can be the right tool in the right hands"
Aug 6, 2014 | 10:13 PM
Mooser
Carb mount nut??
Aug 6, 2014 | 10:37 PM
Cavu2u
Carb mount nut??
Lars looks to be working somewhere near the idle screw in that photo, by the sounds of it, anything could use a tuning hammer
M
