modified angle on the sidepipes
Old Sep 13, 2014 | 09:15 AM
LAddams's Avatar
LAddams
Default modified angle on the sidepipes
Got a set of stainless hookers for real cheap on ebay. PO had straightened out the mounting brackets so the side pipes exit point straight at the ground. I suppose in an attempt to make it quieter?
Im thinking of re-bending the brackets so they aren't pointing at the ground right in front of the rear tire.
Then I was looking at it and thinking it would look cool with the exit pointing at about a 45 degree angle to the ground. Anyone ever do that?
Old Sep 14, 2014 | 06:35 AM
scrappy76's Avatar
scrappy76
Though it is not politically correct, I actually bent the brackets on my sidepipes so I could mount them underneath to the bottom of the frame. I did that so I did not have to mount them undeneath the body trim. Does not change the height or the angle of the sidepipes and you cant see I did it unless you are looking for it. I did keep the exits straight out, I think they look good that way. You can turn them at a 45 towards the ground, that would look good too. I wouldnt think straight down would look good, and you would probably get exhaust fumes bouncing back up towards the floorboard especially sitting in traffic, or at a light.
Old Sep 14, 2014 | 07:21 AM
Phil Zell's Avatar
Phil Zell
Straight down or 45 degree is fine unless you have to drive on a gravel drive way, and take my word, sometime you will. At that time you will find why they should exit out the side.
Old Sep 14, 2014 | 09:28 AM
LAddams's Avatar
LAddams
I did consider leaving the bracket the way it is and mounting to the bottom of the frame. Interesting that its been done. Any pics?
I also considered making a j-hook hanger and hang them from the holes the t-bolts go in.
Old Sep 14, 2014 | 03:43 PM
qwank's Avatar
qwank
i think 45 degrees down would look good
Old Sep 14, 2014 | 10:54 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
I have had both, and split the difference, noise/just a pain to drive.
Driving on the highway listen to both and its easy to decide. Drive-ability/verse being an all you hear is the exhaust and drive-ability will win out all the time.
Its just too noisy, might look cool, still too noisy for me.
Just saying
To modified angle on the sidepipes
