Some rabdom questions, like rorshack.
Old Sep 17, 2014 | 09:41 AM
CVO2FIXUP's Avatar
CVO2FIXUP
Default Some rabdom questions, like rorshack.
1, Did any convertible vettes come a color matched hard top? Could you order the hart top color matched from the factory?
2, When storing the car for the winter, IS it better to let it sit on it's wheels? Or jack it up and put it on stands?
3. I it a good idea to change all the oils ( diff, trans, engine ) to modern synthetics?
4. How far do you guy's drive your 90% original vettes? ( original cooling system, original fuel delivery system )
5. Is it a good idea to rust proof the "inside" of the frame? For preservation.
6. What is the best out door / 4 season / indoor storage car cover?
7. Is it a good idea to do long, smokey burn outs in your pristine vette?
OK, that one is a joke.
8. Is adding a pass side mirror a big no no? If the car did not come with one?
By the way, I have a 1971 BB rag top.
Thanx for all the info, I have a ton to learn here. But I am loving it.
Old Sep 17, 2014 | 10:16 AM
vettebuyer6369's Avatar
vettebuyer6369
Are you talking about a Rorschach Test, or the loud guy from Welcome Back Kotter?
Old Sep 17, 2014 | 10:19 AM
CVO2FIXUP's Avatar
CVO2FIXUP
The psyche test guy. Hey, it sounded correct in my mind only. I will correct my self now, before i'm strung up. Cheers.
Old Sep 17, 2014 | 10:25 AM
CVO2FIXUP's Avatar
CVO2FIXUP
Cant edit the title, From here on in, the word "Rorshack" will actually mean "Rorschach"
Old Sep 17, 2014 | 10:32 AM
early shark's Avatar
early shark
1. All the hardtop were body color from the factory originally.
2. Either will work.
3. I've never worried about it.
4. Everywhere and all the time.
5. I don't believe it is necessary.
6. Don't know as cars are garages when not in use.
7. I've done it.
8. One of my cars has it, added by previous owner.
By the way I have two 1971 big block coupes.
Old Sep 17, 2014 | 10:41 AM
Mike Ward's Avatar
Mike Ward
Jacking it up is a very bad idea if the suspension is left hanging.
Old Sep 17, 2014 | 10:53 AM
Alan 71's Avatar
Alan 71
Hi,
You'll see some vinyl covered hardtops too.
I believe that the vinyl covering (black only) was an additional option (C08) on the hardtop option (C07).
It was quite popular in 68-69 but not so much in 70-72.
Regards,
Alan
Old Sep 17, 2014 | 11:16 AM
joewill's Avatar
joewill
frames will rust from the inside out, yes for complete peace of mind, rustproof the inside of the frame. dip your frame in a huge vat of rust remover or use a service like redi-strip, then dip your entire frame in a huge vat of POR-15, remove and let dry. your frame is now protected from rust inside and outside.
you will need to do the same thing to your birdcage....
Old Sep 17, 2014 | 01:38 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...How far do you guy's drive your 90% original vettes? ( original cooling system, original fuel delivery system )...
What are you wanting to know?
Old Sep 17, 2014 | 02:58 PM
CVO2FIXUP's Avatar
CVO2FIXUP
As a newbie, I just have some concerns regarding the reliability of these 40 some odd year old cars on long trips. Say I want to take my 71 up to the cottage that is 3 hours away, and it 90 degrees out side and I might hit a bit of traffic. Will it over heat? Will it vapor lock? Will it re start once hot? I was wondering what kind or reliability owners are getting with they're "all original equipment" cars. ( stock rads, fuel pumps, carb's etc ) With out leaded fuels its a whole different story for those nice old muscle cars.
Also need to find a killer car cove, that breaths yet water proof and wont scratch. Cheers.
Old Sep 17, 2014 | 03:16 PM
Easy Mike's Avatar
Easy Mike
...I was wondering what kind or reliability owners are getting with they're "all original equipment" cars. ( stock rads, fuel pumps, carb's etc )...
My two are reliable.
...With out leaded fuels its a whole different story for those nice old muscle cars...
Not really. The older cars like leaded fuel, but they'll run on no lead without issues.
No disrespect, CVO, but no one should know your car any better than you. Why be afraid of it? Drive it a while longer, get used to it, then head for the cabin.
Old Sep 17, 2014 | 03:29 PM
Mike Ward's Avatar
Mike Ward
The cars don't suffer one bit from the lack of lead. Old myth.
If your car is as original as you make out, I wouldn't trust 40+ year old rubber fuel coolant and brake lines.
Old Sep 17, 2014 | 03:37 PM
CVO2FIXUP's Avatar
CVO2FIXUP
No disrespect, CVO, but no one should no your car any better than you. Why be afraid of it? Drive it a while longer, get used to it, then head for the cabin.
I am so new to the car world it's not even funny. I just bought the 71 3 days ago. Bin in the Harley world all my life, and still own a 2010 CVO Ultra. Always loved the C3'S and now that I am getting a bit older getting in to the car world seems like the right time. Will still keep the bike as I have $$$$$$$ invested in to it. But I am ready to expend to the cages LOL. The learning curve is steep, so much to understand and absorb over a short period of time. As I hear / read different accounts of Corvette ownership I bring my newbie question here. So thanx for the patience and the good info.
A pick of my HOG.
Old Sep 17, 2014 | 03:38 PM
CVO2FIXUP's Avatar
CVO2FIXUP
OK, here is the pick.
Old Sep 17, 2014 | 03:44 PM
CVO2FIXUP's Avatar
CVO2FIXUP
The basics have bin restored/replaced and its a safe driver from that perspective. Just wondering about the robustness and functionality of the main components in somewhat extreme conditions like traffic in hot weather, or a heavy rain storm, etc. You know things to look out for. Or if you are going to see a lot of hot traffic better replace the rad with a new aluminum one, that kind of thing.
Old Sep 17, 2014 | 04:00 PM
Easy Mike's Avatar
Easy Mike
...I am so new to the car world it's not even funny. I just bought the 71 3 days ago...
That's why I suggested you drive it for a while and get acquainted with it.
...Or if you are going to see a lot of hot traffic better replace the rad with a new aluminum one...
I've had two C3s which were my daily drivers. I drove them in all types of weather, including heat. An aftermarket aluminum radiator is not required if the stock cooling system is otherwise in good shape.
Old Sep 17, 2014 | 04:18 PM
oldgto's Avatar
oldgto
Triple A Premier tows up to 200 miles.
To Some rabdom questions, like rorshack.
Old Sep 17, 2014 | 04:33 PM
lurch59's Avatar
lurch59
Don't forget about the trailing arm bearings!
Old Sep 17, 2014 | 04:34 PM
F22's Avatar
F22
BTDT!
Old Sep 17, 2014 | 04:52 PM
CVO2FIXUP's Avatar
CVO2FIXUP
Originally Posted by F22
BTDT!
Will go under the wives policy for CAA ( its the AAA in Canada ) just to be on the safe side. All I need to do is find a top notch Corvette shop in Toronto ( Ontario ) A place that actually cares about the quality of they're workmanship. No scratches or Baba repairs type of thing.
