383 build or buy?
Old Oct 1, 2014 | 10:50 PM
Cavu2u's Avatar
Cavu2u
Originally Posted by htown81vette
My main complaint with that manifold is that edelbrock insists on putting the vacuum port right under the rear float bowl of the carb. That is to discourage you from using any other carb but theirs (which clears the port 'coincidentally').
It was easily solved for me:
A recessed pipe plug (the internal "hex drive" type) in that port, and use all the ports on the front and back of the carburetor block (yes, a Holley).
But then you may not have a Holley, yes?
Steve
