Vacuum hoses
Old Oct 10, 2014 | 11:30 AM
hardlanding's Avatar
hardlanding
Default Vacuum hoses
does anyone sell a complete engine compartment kit? I thinking I may wanna just redo all of them at once...and are they factory correct?
Old Oct 10, 2014 | 01:03 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Yep. Willcox probably has the kit. I believe ZIP lists it. Corvette Central. If you want repro correct, try Paragon or Doc Rebuild.
Old Oct 10, 2014 | 02:02 PM
Alan 71's Avatar
Alan 71
Hi hl,
Cutting 3/8" off the end of each hose gives a new sealing area on the hose's connections.
Replacing all the hoses rarely cures any vacuum ills, so the cost is better spent elsewhere.
Dr. Rebuild probably has the nicest kits if you decide to replace everything.
Regards,
Alan
Old Oct 10, 2014 | 09:34 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Vacuum Hose & T Kit. 80-82 http://willcoxcorvette.com/product_i...products_id=87
Heater/Air Conditioning Control Vacuum Hose Kit. 77-82 http://willcoxcorvette.com/product_i...oducts_id=6831
Old Oct 13, 2014 | 11:13 AM
hardlanding
Thanks you for all the replies...
To Vacuum hoses
