Can brake calipers be changed from original and car still qualify as original?
Cruising
September 11, 1968 I purchased a 390-427 four speed convertible with hard top. The brakes after 122,000 miles and garaged a lot have gone bad. Two questions: (1) do the original calipers need to be rebuilt for the car to stay original? (2) If they can be changed what is the best way to go?
Thank you, Happy Eddie
Received 2,878 Likes
Hi HE,
Since the brake calipers and rubber brake lines are such important safety items the vast majority of people feel they can be changed without affecting the car's originality.
But, if after determining your caliper's casting numbers and date codes make it possible that these are indeed the calipers the car left St.Louis with, I'd certainly look into having them sleeved and returned to you to use on your car.
With that number of miles on the car (122k) I wouldn't be surprised if the calipers haven't already been changed or sleeved at some point.
I first needed to have my 71's calipers sleeved in about 1982 at about 40,000 miles.
Regards,
Alan
Regards,
Alan
Lonestar calipers will do a sleeping/rebuilding on your original calipers. They also will walk them Dow the line and not do a cosmetic restoration, if you request that. It's a bit more expensive, but some will request that for authenticity sake.
If you like, get your present calipers resleeved, that's about the closest you can get.
Cruising
Hi HE,
Regards,
Alan
Regards,
Alan
You helped me make up my mind, Ed.
Hi HE,
Follow 62's info and make sure whomever you send the calipers to UNDERSTANDS you want these particular calipers back.
Sounds like an interesting history with your car. How much did you drive it in Alaska and how did you store it? How about a couple of pictures?
I was a little older than you when I bought mine, had done college and the military, and had a real job, so in 1971 $5200 wasn't too much of a reach!
Good Luck!
Regards,
Alan
Good Luck!
Regards,
Alan
