Has anyone re-chromed their original factory/OEM ignition shielding parts?
I’d like to use as many of the ‘born with’ parts on my restore. While I don’t have an ultimate goal of having my ’70 judged, I’d like to spruce up the engine bay as part of my restore while keeping it as 'born with' as possible. I know the difference between ‘triple chroming’ and ‘flash chroming’, but am wondering which process would be appropriate on ignition / spark plug wire shielding parts. I’d also like to know if having them done is worthwhile for a restoration, or should I just search for NOS replacements?
One last comment … I’m not planning on re-chroming the distributor cover. It still looks almost new and I don’t want to mess with the plastic rivets.
Hi,
I believe the ignition shielding pieces were 'flash' chromed.
In addition to the 'type' of plating on these parts, the 'preparation' of the parts before plating was minimal and contributes to the look they have.
This not only includes the amount of polishing they received, but also the forming marks that were left in these parts.
I read recently that even the chrome bumpers weren't originally 'triple' plated; they only received a nickel plate and then the chrome plate.
The rally wheel trim rings also received a 'flash' chrome layer right over the stainless steel rings; as did the stainless steel windshield header and coupe roof bar.
If you're serious about "born with parts" then I'd consider the effort "worthwhile"
Regards,
Alan
I agree, but would add that these pieces can be found used in nice condition. If it were me I would save the $$$ for other harder to find and restore.
joe
I had all of my shielding rechromed, 1970, minimual polishing was done in order to retain the draw marks. I rechromed the the three piece ignition box, so the plastic rivets were changed out. Richard Fortier, is my go too guy, to restore my original parts. I can send you photos, if you like, PM me your email address.
Bob
Hi Joe,
Yes there was.
Buddy M. did a very good job duplicating the appearance of the original rivet in what he was making.
I bought several sets, but have had no luck softening the shaft and 'squashing' it to look like the underside of the originals. I guess it's something to do with the material they're made from.
I've gone back to re-using originals.
Regards,
Alan
