Show us your NO or LOW COST HOME MADE do it yourself stuff C3 CORVEtte
#42
One mod I'd really love to try is the electric headlights. I think 7T2Vette did them (correct me if i'm wrong). Besides... already have to replace the vacuum lines so why not try.
Video:
Installed:
Video:
76CSRvette (01-21-2016)
#44
I did this to correct the hood and front surround alignment on my '68 convertible. It not only supports the front surround, but it is adjustable by adding or removing washers (shims).
https://www.corvetteforum.com/forums...t-end-low.html
#46
Nam Labrat
Received 4,179 Likes
"Main leaf while U wait".........................
Blank steel...
Ends get angled.......
Centering bolt-hole is drilled...
Bushing holes are drilled....
Modification of weak original main leaf to provide support/prevent de-arching of the new main leaf....
Blank steel...
#47
Received 3,220 Likes
LED license plate light
Wiper Door-
Daewoo Power Set Motor $14.95 (NEW)
Cherry Electronics E19 Switch $3
Bosch Relays $10
DSCN4655 by richardhayes454, on Flickr
DSCN3839 by richardhayes454, on Flickr
wiperdoorcontrolREVISION by richardhayes454, on Flickr
Electric headlights-
2 Simpson deck Posts $20
2 Heim Joints $5
12" threaded Rod $2
2 Ford Probe Motors $20 ( U Pull It )
Bosch Relay $5
DSCN3036 by richardhayes454, on Flickr
Removable Crossmember- $20 (2" X 3" X 36" steel tube)
Cut crossmember at an angle
Slide in- add mounts and through bolts
DSCN4446 by richardhayes454, on Flickr
Bosch Relays $10
2 Heim Joints $5
12" threaded Rod $2
Bosch Relay $5
#50
I cleaned up the nose of my 75 Vette by getting rid of the line gap between the nose and the body.
Still need to align the hood.
I took out the plastic bumper shock unit, and the boat anchor license plate reinforcement. Shaved about 100 lbs off the front end!
gonzo117 (01-05-2021)
#54
Received 1,127 Likes
#56
Frys around here. Anyplace that sells electronics and has printer ink and paper supplies ought to have something similar. Mine is called "Clear Window Decal Inkjet Film". It would be more durable if I had shot over it with some clear but it's in the car now.
