Battery Question
Old Oct 29, 2014 | 02:39 PM
tdogg21's Avatar
tdogg21
2017 C3 of Year Finalist
Default Battery Question
Hey guys....I have a question about battery size. I have a '69 with the 427 390 engine with some minor upgrades. I replaced my battery last summer and ever since I've had some minor issues starting it. Basically it doesn't seem like it has enough power to crank it a few times. For example, last weekend I decided to take it out for the first time since Corvettes at Carlisle. I put my battery charger on it to make sure it was fully charged. It took a little bit of effort to get it started and after about 3 or 4 attempts (of a maybe 2 or 3 cranks each), I had to put the battery charger back on it. Even if it starts on the first try, I'm fearful going anywhere and turning the car off unless I've driven a decent amount of time first. I keep forgetting to look at the battery size, but looking through my old emails, I think it's a Group Size 86, 640 CCA. Is that too small? What are the rest of you guys using?
Old Oct 29, 2014 | 03:14 PM
chris geckler's Avatar
chris geckler
8th Gear
Hi I had the same similar problem with my 77. I load tested my battery tested good same problem(click,click,click). Now im thinking its the starter. bang starter with hammer still no start???? I fiqure battery & starter about the same cost $$$$. I did what was easier 1st. purchased a bigger battery 800 CC 1,000 Cranking amp's Duralast battery at Autozone.Put battery in problem solved. been driving entire summer not one problem. i also purchased a battery tender for $45 hook it up after driving every time. let me know how you make out
Old Oct 29, 2014 | 03:36 PM
Paul L's Avatar
Paul L
I don't scrimp on capacity: 875 CCA. And that is for a stock 1974 L-48. It works.
Edit**-Motomaster is a Canadian Tire product supplied by Exide.
To Battery Question
