4_speed
Old Nov 3, 2014 | 10:42 PM
thompsonc3's Avatar
thompsonc3
Default 4_speed
I have a 76 stingray that is hard to get out of reverse. Has anybody heard of this before and what can I do to fix it. 4-speed manual
Old Nov 3, 2014 | 10:50 PM
bj1k's Avatar
bj1k
You could have a lock out cable that is freezing up. Disconnect it and see if that helps.
Old Nov 4, 2014 | 05:50 AM
Danish Shark's Avatar
Danish Shark
Could also be the shifter linkage needs adjustment. Reverse has its own shifter linkage.
Old Nov 4, 2014 | 07:38 AM
joewill's Avatar
joewill
need more detail, but probably mis adjusted shifter or worn out shifter bushings
Old Nov 4, 2014 | 07:42 AM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Does it go in and out of other gears ok? Sometimes a clutch adjustment (increase the clutch disengagement) may help with smoother shift transitions.
Terry
Old Nov 4, 2014 | 08:04 AM
thompsonc3's Avatar
thompsonc3
Default 4-speed
Terry
It shifts just fine in all the forward gears,it goes into reverse just fine, when you pull it down it just don't want to pop over into neutral.
Old Nov 4, 2014 | 10:14 PM
thompsonc3's Avatar
thompsonc3
Default 4-speed
I started to remove that cable,and it was already off at the top. But the cable is easy to move. I hooked it back up and it wouldn't even come close to going into reverse. I had to unhook it.
Old Nov 5, 2014 | 11:27 PM
bj1k's Avatar
bj1k
I have a brand new cable on my 72 and it runs hard. It is a poor design that I wish they would have left out all together.
Old Nov 6, 2014 | 07:52 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Happened to me a couple times. The shifter rods were getting all bound up. Had to loosen and then tighten.
To 4_speed
