I have a non-numbers-matching late 69. It has a Chevy crate 350 HO, a 1980 Quadrajet, a composite leaf spring and probably other "upgrades". (Just bought a '74 Tilt/Tele and when it's fully checked out, I will want to trade for a 69. I plan on converting to power windows too.)
I go back and forth as to whether I should just go ahead and "Foosify" the car or if I should try to return it to originality.
What would be the chances of me finding the original block somewhere? Is it a pointless unicorn hunt? If the original block is now machine screws and rebar, is "numbers-matching" completely out of the question or is there a range of 1969 blocks that would be unquestionably OK when installed?
I wasn't sure if "numbers matching" meant a digit-for-digit match to the VIN or if, say, any December 1969 block would be considered a match by NCRS standards.
Chris
Hi Chris,
I would forget about "matching numbers." What NCRS is concerned about is if the engine block in the car is typical of factory production. They would be looking at the casting #, the casting date, the engine suffix and assembly date, the VIN derivative, and finally if the stamp pad looks like the original broach marks.
If you bought a motor from a similarly optioned small block built in the month of December 1969, then the only points you would lose would be for the VIN derivative (because it is not typical for another car's VIN # to be stamped on your motor). But, all else would be right, so to speak.
Here is the NCRS mechanical section score sheet. You can see, if you used my scenario above, you should only lose 25 points out of a possible 350 points.
If your goal is bragging rights at a car show, or judging points, or resale, then it can be done. people do it all the time. but the effort is truly enormous to do it right and correctly and done by the right person. Then you will need the correct heads, intake, carb, exhaust, air cleaner, water pump, hoses, clamps, and so on... its not just the block. getting a date coded block is only a 1st step in the total process.
I suggest you funnel the money and effort into improving the condition of your car.
you will be much happier than spending 4 figures to just put a stamp on the engine pad.
Chris
NCRS wisely avoids the term 'numbers matching' like the plague. No two people agree on the meaning.
Thanks everyone for the great info and opinions. I'll take a stab at finding out what happened to the original block (if nothing else it'll add to the car's story) and keep my eye out for deals on a December small block.
It's good to know that getting close is possible, even if it's a huge effort. Meanwhile I'll focus on the things I don't need to shop for.
@LeMans Pete, you da man!
Chris
In addition to it being the correct casting number and having an appropriate casting date, the block must have originated at the Saginaw foundry and not Tonawanda or St. Catherines. Many fakers have found out the hard way..................
I hope you understand that you're in for a lot of time, money and trouble with very little return on investment.
Thanks,
Chris
Seriously?. Nill. Your chances of finding the original engine are nill. Not gonna happen. Nope. Nadda. Not a chance. So, what are your plans?
Could you find a correct era block and heads? Yes. Could you machine the the deck and re stamp the block? Yes. So does this make your corvette a numbers matching car??????? Lots of them are out there. But what does this really, seriously bring as far as value at resale? 1k? 2K? 3k? Can you back it? It has been said that there is far more "insert car" for sale than was ever produced. I say, if your all about the numbers, best start with a real numbers car.
As soon as it starts to snow the 12/69 coupe will be getting it's new engine. The 101,000 mile OEM engine will be moth balled for any future owner of this car if they ever see any reason to rebuild and reinstall. I'm sure I'm not the only one with OEM engines laying around. I've saved every hard part that came off this car including the bolts. Even have the OEM block from the 6t8. T
That's exactly where I'm starting. I know who owned it prior to the guy I bought it from, and I'm pretty sure he/she would have been who replaced it (the registration card was put inside the 350 HO crate engine's booklet).
I have thought about reaching out to them to ask about the car's history as they know it and why they sold it, but I guess I've been uncomfortable with intruding on their privacy. I guess it can't hurt to write a letter though, right?
In my head, I have formed a story about a guy like me who was really enthusiastic about making a fast, cool car until he woke up one morning to find it half under water and that just took the wind out of his sails and he gave up and dumped it. But I totally made that up...
Another thing I'd like to know is why the pattern of body repairs makes it look like someone went around the car swinging a sledge hammer and a pick axe (first owner's bad divorce?)... Does not look like any auto accident damage I've ever seen.
There is a good reason the original block is no longer in the car. Who do I know? I searched for my original block and when I found it there was a hole in the side where it threw a rod.
Yeah, this is pretty much what I would expect to find. That's why I quickly started thinking of how close I could even hope to get. The scoring card that Pete attached is an awesome resource to have in that regard!
Then again, an LS1 with coil packs and a Quaiffe sequential gearbox would be really fun to drive!
The NCRS points sheet is nice to have for general knowledge, but it doesn't apply out in the real world where it's either the original born-with engine, or isn't. Kinda like being partially pregnant.
The original engine on my car was destroyed by the first owner. He thought the 'oil pressure' gauge was an 'oil quantity' gauge and saw nothing wrong with 5 psi at 70 MPH.
Wonder if it could be repaired? I've heard of some who go to extreme lengths to save the original block.
