Advice on puting a LS1 into an 82 CE
Old Nov 18, 2014 | 05:07 PM
ZR11990fixed's Avatar
ZR11990fixed
Default Advice on puting a LS1 into an 82 CE
I bought a trashed out 82 CE for $2000. Im going to do a frame off and put a ls1 with a 6 speed tranny in it. Has anyone here done this and can they give me advice on where to get conversion parts needed to do the swap.
Thanks in advance
James
Old Nov 18, 2014 | 06:48 PM
74modified's Avatar
74modified
Its been done hundreds of times. Do some searches here, and at LS1tech. You will find several threads. I don't know of any "kits" for putting one in. Just about every swap has some differences, due to the original equipment, and what will be installed. Don't buy anything until you do a lot of research. There are several ways to do each change, and you should pick what would be best for you and your expectations.
Old Nov 20, 2014 | 04:59 PM
terry82's Avatar
terry82
https://www.corvetteforum.com/forums...x-my-swap.html
Old Nov 21, 2014 | 07:45 AM
Garys 68's Avatar
Garys 68
This ought to help
https://www.corvetteforum.com/forums...directory.html
To Advice on puting a LS1 into an 82 CE
