Which engine bay paint?
Old Nov 26, 2014 | 06:28 AM
havesometo's Avatar
havesometo
Default Which engine bay paint?
I've done a search and all I can really find is Krylon 1613. But I can't find it anywhere in stores and I've read it's been discontinued. What is everyone using now?
Old Nov 26, 2014 | 07:25 AM
Mooser's Avatar
Mooser
I used several products in various areas but found the John Deere Blitz black to be a pretty good semi-flat paint.
Most any JD dealer or service center carries it, a little spendy since it has JD on the side but did a nice job.
M
Old Nov 26, 2014 | 07:32 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Old formula Krylon (5-Ball) is now considered an industrial coating. You can still purchase the old formula from industrial coating outlets. You can also get it off eBay.
Old Nov 26, 2014 | 07:53 AM
SB64's Avatar
SB64
Went through the same thing, go Travers Tool Co.com
Bought 6 cans from them no problem the real deal.
Roger
Old Nov 26, 2014 | 09:16 AM
Street Rat's Avatar
Street Rat
I was reading another thread that also suggested the John Deere paint. That's what I plan on using.
Old Nov 26, 2014 | 09:33 AM
71scgc's Avatar
71scgc
Buy Krylon 1613 from MSC industrial supply.
They have a discount for CF members. Mention it to whomever answers your call.
Very nearly 1/2 price. I buy it in the 6 can case.
World's fastest shipping, I promise you. I've ordered twice and received it THE NEXT DAY!
Carter
Old Nov 26, 2014 | 09:46 AM
havesometo's Avatar
havesometo
Carter
Can you please tell me how to get in time contact with them?
Old Nov 26, 2014 | 10:26 AM
PHIL 68's Avatar
PHIL 68
Lots of it for sale on ebay prices are all over the place. Phil
Old Nov 26, 2014 | 10:55 AM
69FASTFUN's Avatar
69FASTFUN
I am the one that set up pricing at MSC since I work there
We have 2400 cans in stock
current price $4.54
Krylon 1613
Call 800-645-7270
Account # 3682266 C3 Corvette Forum
Identify yourself as a new buyer and they will take your shipping info
order 00264671 Krylon semi flat black case quantity is 6 but you can order what you need.
After the order you will get a confirmation by email
when it ships you will get a tracking code should take 1 to 2 days
Andy
Old Nov 26, 2014 | 11:06 AM
Alan 71's Avatar
Alan 71
Hi Carter and Andy,
Thanks for the info.
I've been buying 1613 from someone in California and find out MSC is about 25 miles away!!!!
Regards,
Alan
Old Nov 26, 2014 | 11:40 AM
havesometo's Avatar
havesometo
IUOTE=69FASTFUN;1588350107]I am the one that set up pricing at MSC since I work there
current price $4.54
Krylon 1613
Call 800-645-7270
Andy[/QUOTE]
Ijust ordered a case. Thank you very much
Old Nov 27, 2014 | 12:59 AM
BLUE1972's Avatar
BLUE1972
used rust-olium on my truck held up very well, semi- gloss shine is somewhat off.
Will try the 1613 on my 71.
thanks
Old Nov 27, 2014 | 03:33 AM
hunt4cleanair's Avatar
hunt4cleanair
What's the shelf life of a case? Plan a project but not for another year or so.
Old Nov 27, 2014 | 05:39 AM
MAP73's Avatar
MAP73
I used to use Krylon until years ago a Chevelle guy turned me on to Rustoleum 7777. It gives the same gloss as the other but is much more durable. It comes in spray cans as well as quarts and is available at Walmart and Lowes. It does take a long time to dry but when it gets hard it is durable.
I use it on engine bays as well as engine pulleys and brackets. I like the fact that I can spray it from a gun on large areas if needed.
just my .02
Old Nov 27, 2014 | 07:41 AM
79C3tnd's Avatar
79C3tnd
Here is the link to MSC:
http://www.mscdirect.com/product/det...rItem=00264671
I agree with the others here o the forum, years of using this have proven it to be the "right" gloss, it is dead-on in my book. However, I will also say that it is not the best paint in terms of durability. Perhaps I should buy a can of the rustoleum and compare...
Old Nov 27, 2014 | 08:04 AM
SB64's Avatar
SB64
current price $4.54
Krylon 1613
Call 800-645-7270
Andy
Ijust ordered a case. Thank you very much[/QUOTE]
Looks like the price is $7.29 whats up with that?????
Old Nov 27, 2014 | 08:16 AM
havesometo's Avatar
havesometo
Looks like the price is $7.29 whats up with that?????[/QUOTE]
Did you give them the account number? Mine was only $4.50 a can.
To Which engine bay paint?
Old Nov 27, 2014 | 09:14 AM
SB64's Avatar
SB64
Did you give them the account number? Mine was only $4.50 a can.[/QUOTE]
NO, guess I need to do that ,OOOOOPPPPS!
R
Old Nov 27, 2014 | 09:23 AM
Alan 71's Avatar
Alan 71
Hi H4CA,
I had some unused cans of #1613 that were about 8 years old and seemed to work fine.
On partially used cans it seems more about luck whether the nozzle or the siphon tube gets clogged with paint.
You certainly would be good for 5 years unused.
Regards,
Alan
Old Nov 27, 2014 | 09:27 AM
69FASTFUN's Avatar
69FASTFUN
I checked the price they must not have used the correct account number
because it shows $4.54 per can
