Does anyone know who does restoration on the c3 rocker panels (72)? The only person I can find locally or near me said they could do it, in 4-5 months. That doesn't do me any good, so looking for other options. I tried a pair of the reproduction panels, they were not even close to fitting. Thanks!
Hi frb,
Finding anyone who can/will do it period, is quite amazing.
It takes some special abilities to strip and then prep the aluminum to look like it did originally, and THEN, have the ability to anodize something of that length.
The reproductions can be made to fit quite well with a bit of finessing.
Regards,
Alan
Alan, thanks. The repros I got don't even come close to fitting. They are going to send me another set to try. In the meantime I am going to polish mine.
I found a couple people to restore them. I knew the cost was going to be high but it was higher than I even thought. I was getting quotes ranging from $700 to $1200 depending on condition.
Hi 63,
That's the $ range I've been hearing too.
One of the problems is that since the trim is mounted so low, and the aluminum is so soft, the aluminum actually gets stone and gravel 'pock' marks in it.
If the aluminum is 'surfaced' enough to get rid of these 'pocks' it will become very thin and even more fragile than the originals already are.
I hear about 'restored sets' but have not actually seen another besides the set I bought.
I really thought I was crazy spending the money at the time, but the situation doesn't seem to have gotten any better since.
Regards,
Alan
Hi frb,
Someone who is sorta retired from the reproduction business had a set restored to see if it was reasonably possible for him to begin offering the service or to begin offering restored sets.
It was such a problem (at least with his sources for the restoration work) getting them done satisfactorily that he did just one set and called things to a halt. (I don't know if that situation has changed or not.)
I was told about the set he had at just the right time and bought them.
I hear and read about people doing all sorts if things to the panels, but I'm not sure just how close any of these end up looking like original panels. Plus I don't really SEE any results.
I'm NOT saying it can't be done, but this has to be one of the oddest processes, on one of the oddest materials, that restorers deal with.
I'd think the fact that there continues to be talk about 'better' reproductions being on the horizon discourages people from working out the process to restore the originals.
Regards,
Alan
