Side Pipes on a C3 problem
Old Dec 4, 2014 | 10:42 PM
papawana's Avatar
papawana
Default Side Pipes on a C3 problem
I am in the process of putting the complete Corvette Central 454 side pipe kit 323152 on our '78 Corvette using Headman Hedder side pipe headers H68286...the headers come to a 3" flange and come with a reducer that brings it down to 2.5"...I am going to reduce that down to match up to the 2"pipe on the side exhaust muffler...upon first mock up I see the rear of the mufflers hang about 1.75" too low to meet up with the cover, and the tip is angled up too much...it looks like I am going to have to heat off the rear muffler mount that goes to the frame spot and reposition it on the muffler to pick up the missing height...then bend the mount so that the exit of the muffler matches that of the cover...has anyone else run into this terrible problem?...I have been restoring the car from a wheel chair since July...now I have to have surgery after tearing my right shoulder's rotator cuff...what a klutz
Old Dec 4, 2014 | 10:48 PM
MrJlr's Avatar
MrJlr
Restoring a car from a wheelchair? You are one bad a$$ momfo
Can't help you with the side pipe problem but wanted to say that's pretty cool!
Old Dec 4, 2014 | 11:48 PM
persuader's Avatar
persuader
I can't help you either Papa. But I also just had to give you props for your dedication. Sounds like you have it figured out though.
Old Dec 5, 2014 | 12:03 AM
papawana's Avatar
papawana
Default side pipes
you guys are both trips age and physical limitations never come between a Marine and his Corvettes
Old Dec 5, 2014 | 01:38 AM
Bangkok Dean's Avatar
Bangkok Dean
As they say, when brute force don't work ...use more brute force.
Old Dec 5, 2014 | 06:01 AM
oldgto's Avatar
oldgto
Yup! Building a 1931 Chevy long ago, one corner of the body was 1/4" low, causing the body lines to not match up.
Wife says....
"Well, you have a sawzall and a grinder.... FIX IT!"
I spent the next 2 weekends cutting, grinding, & re-welding.
I predict sparks in the future of your side pipes!
Old Dec 9, 2014 | 07:31 PM
qwank's Avatar
qwank
putting those stock pipes on a 454 is going to rob a ton of power. I put 3'' pipes behind my stock style covers with auger inserts. 3'' fits great and you don't see the pipes hanging down under the cover like most stock pipes do
Old Dec 10, 2014 | 10:14 AM
papawana's Avatar
papawana
Default pipes
the engine is a 350...Corvette Central told me the 454 mufflers were louder
Old Dec 10, 2014 | 11:00 AM
qwank's Avatar
qwank
oh, ok. I thought you meant the whole 454 kit including pipes and manifolds etc.
I believe the mufflers are the same, but the pipes are different. You might need to return it and just get the small block kit for a direct bolt on.
To Side Pipes on a C3 problem
