Black Dye interior pics
Old Dec 7, 2014 | 04:22 PM
flyinrazrback's Avatar
flyinrazrback
Default Black Dye interior pics
Does anyone have pics of their C3 that they used the Corvette America black dye on the interior pieces? Is the black high gloss or more dull? Thinking of changing interior color from blue to black on my 72.
Old Dec 7, 2014 | 05:45 PM
7T1vette's Avatar
7T1vette
Using any spray can stuff via mail-order is a 'crap-shoot', IMO. There have been many posts on the CA spray dye: some do OK; many have poor results.
If you want to change the color of your interior, use the right product for that job. SEM "ColorCoat" vinyl dye--liquid form, sprayed on--is the "right stuff". Other name brand dyes (not regular 'paint') do well, also; but I have always used the SEM dye, mixed to my interior color code, and have NEVER had any negative results. In fact, all results have been extremely positive...for being easy to spray, easy to cover, to covering well (two light, covering coats will change any color to any other color), to never peeling or wearing off. I've even sprayed a black leather-wrapped steering wheel so that it would match my interior. No cracks, wear, peeling, or change in color after 5 years!!!
Why would you want to chance a mail-order spray bomb when you can get the 'best' locally. Call around to some professional auto body paint supply stores. Many have mix-to-order dye available. And, if you don't have spray equipment, just buy a Pre-Val bottle sprayer with 2-3 extra gas canisters. Low dollar (about $10 plus a few bucks for the extra gas canisters) and it will do a GREAT job with the thin, SEM ColorCoat vinyl dye.
P.S. For good results, you MUST clean all surfaces with detergent (to get rid of all the oily 'protectants' you used on your interior parts), rinse WELL to get rid of all detergent, then let dry completely. If you do that and use SEM dye, you will not have to use a primer product, first. Other products may require a primer to get good adhesion.
Old Dec 7, 2014 | 06:02 PM
flyinrazrback
Thanks, I will see if I can get the SEM locally. Is their black a gloss? Trying to keep a stock sheen look.
Old Dec 7, 2014 | 10:11 PM
1974ta's Avatar
1974ta
Default Sem
Totally concur with 7T1vette.
SEM Landau Black is about perfect for a C3. It is not high gloss.
I used it to dye an NOS parking brake console, kick panels and to freshen up rear storage, jack, battery frame. Even used it on my steering column and it looks factory IMHO. Lastly used it on the shoulder belt harness cover on 70 vert.
Bill
Old Dec 9, 2014 | 01:41 AM
Joe Papa's Avatar
Joe Papa
Here are pix of some peices that colored using their black dye. It's more of a satin finish.
Old Dec 9, 2014 | 08:27 AM
70BBvert's Avatar
70BBvert
I used SEM interior dye as well. Had a combination of black & green interior parts. I used Landau black color coat Part # 15016. Sprayed all the parts so they'd all be the same color after a thorough cleaning. Still have material left in the Qt can.
Jim
A few pictures
Old Dec 9, 2014 | 09:08 AM
flyinrazrback
Thanks for the pics, looks great! Think I will go the SEM Landau Black route.
Old Dec 9, 2014 | 11:14 AM
70BBvert's Avatar
70BBvert
Thanks, it has held up well, I think they were sprayed in July 2011. These are from a recent photo shoot. Ignore the dirt on the carpet
Jim
To Black Dye interior pics
