74 Smog Equipment
Old Dec 10, 2014 | 12:13 PM
blkvette85's Avatar
blkvette85
Default 74 Smog Equipment
I just got a 74. My first C3. What kind of smog equipment should it have? Engine is a 350 L48 4 speed with air (CKZ). It is all original numbers matching. It does not have an air pump. I checked the manifolds to see if possible the air tube holes might have been plugged and it does not appear they were ever drilled for the tubes!
Its also a late build car. June 21,1974.
Old Dec 10, 2014 | 12:29 PM
Kris Tunetso's Avatar
Kris Tunetso
Are you certain it's numbers-matching, or is that just what you were told when you bought it? Im not trying to rain on your parade, it's just that a lot of new owners buy "numbers-matching" cars only to later find out from the very knowledgeable people here that they aren't. If it IS numbers-matching and has no AIR pump or holes in the manifold, then you likely have a car that never was smog-equipped.
Up until the late 70s (I think) cars only had smog equipment if they were being shipped to CA or a "high-altitude" state. It may be possible to determine if you have a smog car by decoding the VIN, but I cannot say for sure. Im sure there are others here that can tell you better than I.
Old Dec 10, 2014 | 12:34 PM
blkvette85's Avatar
blkvette85
positive it is matching numbers. checked the numbers on the block. Also, there are not extra groves in the pulleys.
Old Dec 10, 2014 | 12:46 PM
Kris Tunetso
Then odds are your car never had smog equipment. Even catalytic converters weren't put on the cars until 75 or 76, I think.
This thread should get more traffic this evening once everyone's home from work. That's when the more knowledgeable folks are likely to show up and comment. Post up some pictures for everyone to look at too: we all like looking.
Old Dec 10, 2014 | 12:47 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
L-48s may not have had AIR. I can't check until this evening.
Old Dec 10, 2014 | 01:05 PM
Mike Ward's Avatar
Mike Ward
Sorry but both statements are false. All Corvettes had varying types of smog equipment going back to the mid 60s. The VIN contains no info regarding smog info either.
I believe that '74 L-48 with 4 speed had an AIR system, plus EGR plus TCS. Auto trans did not have AIR.
Old Dec 10, 2014 | 01:19 PM
Paul L's Avatar
Paul L
Mike is correct. The 1974 L-48 (non-California) with TH400 did not have an AIR pump. I verified that with GM at one point. But the L-48 with manual transmission should have the pump.
BTW I have never figured out what a "thermostatically controlled air cleaner" is...or "carburetor heated air".
Old Dec 10, 2014 | 02:36 PM
Kris Tunetso
Hence why I said "I think" and "I cannot say for sure." I stand corrected. Thank you gentlemen.
Old Dec 10, 2014 | 02:41 PM
Mike Ward's Avatar
Mike Ward
The first is a vacuum activated valve built into the snorkel of the air cleaner that selects either warmed air from the outside of the exhaust manifold via a tube or fresh air. It's thermostatically controlled according to coolant temp.
The second could mean the same thing or the heated passage inside the intake manifold.
Old Dec 10, 2014 | 02:54 PM
Paul L's Avatar
Paul L
I had that system on my 1979. The 1974 Corvette does not have it. Perhaps passenger cars had it but not the Corvette. Hence my confusion. Perhaps that spec sheet is wrong. Does the 1973 have it?
Old Dec 10, 2014 | 03:07 PM
toylman's Avatar
toylman
Here's a picture of a '74 l48 4 speed I owned. It had a 29199 diverter valve, 7801149 pump and 3917234al pulley. Also was Bloomington gold/survivor and NCRS top flight implying all was correct. I agree with the others that said check your "numbers" since you don't have plugged exhaust manifolds.
74eng by toylman, on Flickr
awards by toylman, on Flickr
Old Dec 10, 2014 | 03:16 PM
Mike Ward's Avatar
Mike Ward
Nope. Maybe '76?
Old Dec 10, 2014 | 03:51 PM
Paul L's Avatar
Paul L
Nope. Maybe '76?
Toylman has a good pic. Those air cleaner base vacuum valves are not there. Nor are they on mine. That spec sheet was probably mixing cars without cowl induction in with Corvettes. Bureaucrats sometimes foul up. In any case this should not detract from the original question. The OP's car should have the AIR pump.
Old Dec 10, 2014 | 04:05 PM
gbvette62's Avatar
gbvette62
Nope. Maybe '76?
1976 was the first year the Corvette used the "Thermostatically Controlled Air Cleaner", though other Chevrolet's came with it as early 70 or 71. It was on all Corvettes from 76 on. It's pretty easy to identify. Any car that has a "stove pipe", or tube running from the exhaust manifold to the air cleaner, has it.
I agree with Paul 74, in regards to 74's with A.I.R. Federal Emission 74 L-48 automatics didn't use it, but all other 74's did.
Old Dec 10, 2014 | 07:14 PM
Paul L's Avatar
Paul L
It does make you wonder how the Motor Vehicles Manufacturers Association (MVMA) could get it wrong for the 1974 Corvette.
Old Dec 10, 2014 | 07:57 PM
Peterbuilt's Avatar
Peterbuilt
Look just to the rear of the master cylinder the ZB sticker will say:
Automatic Manual
CCS-EGR AIR-EGR
more 74 trivia.
http://www.motorera.com/corvette/1970/vet74.htm
Old Dec 10, 2014 | 08:20 PM
walt wells's Avatar
walt wells
2nd Gear
Just for information, my 73 L48 with th400 trans originally had an air pump. The car was delivered through a Maryland dealer.
To 74 Smog Equipment
Old Dec 11, 2014 | 08:46 AM
blkvette85's Avatar
blkvette85
Thanks for all the info. I guess I have more reach to do on my Vette.
Old Dec 11, 2014 | 09:17 AM
Paul L's Avatar
Paul L
OK, one last comment. This is the emissions tag on my 1974. Note CCS/EGR for automatic and AIR/EGR for manual.
Old Dec 12, 2014 | 09:37 PM
LS4 PILOT's Avatar
LS4 PILOT
My auto L48 74 coupe never had a smog pump that I ever saw , no sign of brackets or manifold with holes, it was bone stock far as I know when bought it engine wise . ....well,save the side pipes.
The 4 speed L48 did come with a pump setup . I think there are pics of all the possible belt configuration in the AIM.
