Protect-O-Plate Decoding Help
Old Dec 15, 2014 | 06:28 AM
Trae1971's Avatar
Trae1971
2nd Gear
Default Protect-O-Plate Decoding Help
Could someone please help me decode this Protect-O-Plate. I'm buying a 1971 Corvette and want to make sure of what I'm getting.
V0202CJL 194371S109578
LRW032E R P1T18
1 3 3 B
Old Dec 15, 2014 | 07:47 AM
jhudec's Avatar
jhudec
Base motor 4 speed built feb 2nd 1971.
Old Dec 15, 2014 | 08:23 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Trae1971
...V0202CJL...
Engine ID
...194371S109578...
VIN
...R...
Rochester carburetor.
The AIMs usually have a page designating what the specific POP codes should be.
You want to verify the numbers on the car, not what's necessarily on the POP.
Old Dec 15, 2014 | 08:50 AM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
LRW032E R P1T18
1 3 3 B
You know the engine code and VIN invormation above.
LR is your rear end code, which is a 3.36 posi gear. "W" is for the Warren plant on the 32nd day of 1971, E is for Eaton.
P is for muncie, 1 is the year (1971), T18 is December 18th of 1970.
Old Dec 15, 2014 | 10:02 AM
Alan 71's Avatar
Alan 71
Hi T,
Here's an example of the info Pete posted.
My 71's p-o-p plate is stamped LRW012E
And here's the stamp on the differential carrier. (The last 1 is the shift the unit was assembled.)
This is a example of "numbers matching" going far beyond the engine's stamp pad.
Where the p-o-p you list is stamped B (for February assembled car) mine is stamped A (for January assembled car).
Regards,
Alan
Old Dec 15, 2014 | 06:37 PM
Trae1971's Avatar
Trae1971
2nd Gear
Default POP Decode
Thanks for the help!!
To Protect-O-Plate Decoding Help
