Replacement Heater Core fit
Old Dec 15, 2014 | 02:26 PM
Ike27's Avatar
Ike27
Default Replacement Heater Core fit
Hello
Has anyone else to do some fitting with replacement heater cores? I had mine tested and then began fitting it. The two straps needed to be modified to hold the thinner core. I also had to modify the shield that covers the outlets. I was unable to mount the spacer (stay) that holds the two tubes.
Anyone else need to make changes.
Old Dec 15, 2014 | 02:38 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I've replaced one factory air core and one non-AC core without having to modify anything for either. Are you sure you have the correct core?
Old Dec 15, 2014 | 02:55 PM
Ike27's Avatar
Ike27
Mike,
Yup.. Ecklers 26247. I wont be able to use the spreader that screws in but other than that its ok. Core is 1/8 thinner which made the retainers a bit loose.
Old Dec 16, 2014 | 07:49 PM
The Hot Rod Grille's Avatar
The Hot Rod Grille
2015 C3 of Year Finalist
I replaced the heater core in my '70 LS-5 non-air car and had no problems! The heater core was purchased from Zip and was an exact replacement.
Jim
Old Dec 16, 2014 | 08:08 PM
Ike27's Avatar
Ike27
Thanks Jim
Well its in and done. I cant believe what you need to disassemble to do it. Its true when they say the car was built around the box.
That just made me discover that the blower motor needed to be replaced.. so as with any Vett... Loosen the AC belt, remove radiator overflow bottle, then remove the blower motor.
Old Dec 17, 2014 | 07:57 PM
C3 4ME's Avatar
C3 4ME
I've got the dashboard completely out of my 79 as I type for this exact reason. Just waiting to see how much money I"ll have left from Christmas before I start putting things back together. There's plenty of "while I'm at its" I want to tackle.
Old Dec 17, 2014 | 08:16 PM
Too Slow '90's Avatar
Too Slow '90
Timely topic. I was just getting ready to ask the same question. I just returned one for that very reason. It was about 1/4" thinner than the one I removed however the replacement was an aluminum unit. Anyone know where to find a quality copper (American Made?) replacement?
Old Dec 17, 2014 | 09:25 PM
The Hot Rod Grille
The heater core from Zip was an exact replacement in size and appearance. It was a well-made copper unit, althought I seem to recall that the box said the core had been made in Mexico. Again, this was in a '70 big-block, non-air car. I installed the heater core from the engine compartment while I had the engine out. The install went fine with no problems. Zip part # M-325, 68-79 heater core w/o AC, $62.95
Old Dec 17, 2014 | 10:44 PM
gbvette62's Avatar
gbvette62
It seems to me that the non AC heater cores, usually dropped right in, but the AC ones always seemed to be a struggle.
It didn't make any difference if it was an AC Delco part, or a replacement one either. The cores for air conditioned cars, never want to go right in. The problem comes from the length of the tubes, and the bends in them.
Old Dec 18, 2014 | 09:45 AM
Ike27's Avatar
Ike27
My Ecklers core is copper and well built. The only thing I did was reshape and shorten the two straps and then left off the spreader. the gasket that slides onto the pipes to seal it form the outside will keep them separated.
Other than that its a good fit.
To Replacement Heater Core fit
