LT1 Body Identification Numbers
Old Dec 17, 2014 | 06:43 PM
bj1k's Avatar
bj1k
Default LT1 Body Identification Numbers
Just wondering if there are any numbers on the body or in the VIN to identify if a car was an LT1. Not that it is important because my 72 doesn't have the original engine , but curious because it has an LT1 hood and dual snorkel air cleaner. I was told that the original engine was removed to install a high performance race engine and the previous owner couldn't tell me where the original engine was.
Old Dec 17, 2014 | 07:05 PM
Mike Ward's Avatar
Mike Ward
The fifth character in the VIN would be an L if it was an LT!.
K is base engine and W is the LS5
Old Dec 17, 2014 | 10:37 PM
bj1k's Avatar
bj1k
Thanks Mike , I'll check that out.
Old Dec 18, 2014 | 07:44 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Other than the VIN code, there would be nothing on the body which would be LT-1 specific. The car would have been a regular production coupe or convertible with the LT-1 option package added.
Old Dec 18, 2014 | 08:00 AM
Revi's Avatar
Revi
There are a few other items that you can use as clues to help determine how the car was delivered, but these may have been changed as well. (Most people wouldn't catch all of them.)
FYI- LT-1's where delivered with Open Element Air Filters.
The LT-1 has a 6500rpm tach, unless it was one of the few delivered with A/C (5600rpm redline).
The LT-1 used a Holley carb. There should only be one fuel line from the fuel tank to the fuel pump. Quadrajet equipped cars (Base and LS-5) would have two fuel lines from the tank to the pump.
The LT-1 and LS-5 half shaft clamps were Heavy Duty and look like blocks, while the base engine cars clamps look like straps.
Old Dec 18, 2014 | 09:32 AM
jhudec's Avatar
jhudec
Also a single fuel line that can be seen at the frame rail by the fuel pump.
Old Dec 18, 2014 | 10:00 AM
bj1k's Avatar
bj1k
Confirmed that it was not an LT1 , so not really important that it's not the original engine.
To LT1 Body Identification Numbers
