Trim Ring Size
Old Dec 21, 2014 | 09:26 PM
Vandros's Avatar
Vandros
Default Trim Ring Size
Hi,
Getting a 72 Vette and the trim rings on it don't seem as deep as my old ones. Do they come in different depths?
The picture is on a correct 15 x 8 AZ wheel rim, is it the correct Trim Ring size?
Old Dec 21, 2014 | 09:31 PM
my 76 ray's Avatar
my 76 ray
Trim rings do come in different depths.
Old Dec 21, 2014 | 09:35 PM
gcusmano74's Avatar
gcusmano74
Yes. The Corvette trim rings were the deepest, to accommodate the 8" wide wheels (that were installed from '69 on, I believe). The Camaro and Monte Carlo used wheels that were narrower, and used smaller rings.
Old Dec 21, 2014 | 09:47 PM
Vandros's Avatar
Vandros
Thanks Guys
Seems Eckler's suggests 3" deep is the correct size for a 72. I'm assuming the above picture must be 2.5" deep trim ring?
http://www.ecklerscorvette.com/corve...1968-1982.html
Old Dec 22, 2014 | 10:02 AM
Alan 71's Avatar
Alan 71
Hi V,
The trim rings for 68+ Corvettes were all the same depth. The ring was closer to the center on a 68, 7" wheel, than on a 69+ 8" wheel.
All 68+ rings were 3" deep.
Regards,
Alan
Old Dec 22, 2014 | 10:33 AM
Vandros's Avatar
Vandros
Thanks Alan.
Old Dec 22, 2014 | 04:02 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Also note, unless they are the 4 clip trim rings, they could be almost any depth. The originals had one of the 4 clips located at the stem hole. Over the counter replacements had the clips rotated 45* from the hole.
To Trim Ring Size
