74 4speed manual wiring
Old Dec 27, 2014 | 07:17 PM
LAddams's Avatar
LAddams
Default 74 4speed manual wiring
Getting my project car to the stage where I'm buttoning up the wiring. On the 4 speed there's 1 2 wire connector and a spade terminal. At first I thought the 2 wire connector would be the neutral safety but from diagrams and searching around I see it must be the reverse lights switch. I'm not finding what the other thing is. It screws in under the front most shift rod on the bottom of the trans and looks like a temp sender with a single spade terminal sticking out the bottom. Figure someone must know what it is.
Old Dec 28, 2014 | 09:10 AM
Alan 71's Avatar
Alan 71
Hi LA,
The one in this location?
On a 71 it's a post connector and is part of the CEC system. In signals when the transmission is in 3rd and 4th gear.
Regards,
Alan
Old Dec 28, 2014 | 09:49 AM
LAddams's Avatar
LAddams
That looks like the one. My car came with an aftermarket carb so I wouldnt have the cec valve on the carb to hook it too. Ok one less thing to worry about. Thank you.
To 74 4speed manual wiring
