under dash bracing pics
Old Dec 28, 2014 | 10:57 PM
73silververt's Avatar
73silververt
Default under dash bracing pics
My 73 convertible w/ac was a mess when we got it, a lot of sorry repair work, missing parts, but we're working on making it right. Missing most of the dash bracing (bracing rods) and maybe even some of the attaching points have been eliminated. I find the assembly manual lacking in showing what should be there and detail in attaching points. All I have now is the huge metal plate that is rivited to floor at trans tunnel with one brace going to right side of steering column support, and another from left side of steering support to left door pillar frame. Does anyone have pics of there dash apart and the bracing intact? Trying to track down parts.
Old Dec 29, 2014 | 05:25 PM
Paul L's Avatar
Paul L
What do you wish to see?
Old Dec 29, 2014 | 05:42 PM
73silververt
I'd like to see a photo of another car with braces intact, I've got the assembly manual, would like to see a real car with braces in place, manual shows 5 braces, gives three part numbers (don't think those #'s will help anyway)
Old Dec 29, 2014 | 06:43 PM
Paul L's Avatar
Paul L
I'll try.
Upper.
Lower (since painted).
That's basically all I have for you.
Old Dec 29, 2014 | 07:06 PM
mysixtynine's Avatar
mysixtynine
I have the same as Paul plus these on my drivers side
Old Dec 29, 2014 | 07:11 PM
Paul L's Avatar
Paul L
Thanks sixtynine. I did not pull the dash side. My job was "just" an A/C heater core. Great pic of the other side. I would guess the OP has the full picture now.
Old Dec 29, 2014 | 08:26 PM
PUNISHER VETTE's Avatar
PUNISHER VETTE
When were these braces first used in production?
This is the first I've ever seen them and I'm feeling kinda left out my '69 doesn't have any...
they look useful to stiffen things up!
Old Dec 29, 2014 | 08:35 PM
Paul L's Avatar
Paul L
Good question. I do not know the answer. They were used for convertibles.
Old Dec 29, 2014 | 09:26 PM
mysixtynine
My understanding is they came out in 69 my friends early 68 did not have them and I believe they were only used in convertibles due to the cowl shake.
Old Dec 29, 2014 | 09:59 PM
mikem350's Avatar
mikem350
Do a search on cowl shake..LOTS of info there! BTW my 71 vert has some braces but in way different positions as the 74 shown
Seems they interfere with aftermarket AC units...
Old Dec 29, 2014 | 11:10 PM
mysixtynine
Originally Posted by mikem350
Do a search on cowl shake..LOTS of info there! BTW my 71 vert has some braces but in way different positions as the 74 shown Seems they interfere with aftermarket AC units...
Yea I put vintage air in mine and I worked all of the braces back into mine. It added a bit of a challenge. I posted my install and pics. The whole thing was a challenge.
Old Dec 29, 2014 | 11:16 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Looks like I'll have to check my AIM. I've got the brace marked 6 but I've never seen 1 or 3. Mine's a 73 roadster.
Old Dec 29, 2014 | 11:24 PM
JC68's Avatar
JC68
Punisher
The braces were added mid production in 1968 to all convertibles, and to coupes equipped with A/C. The approximate date they were added to production is March 1968.
The brace configurations changed over the years so not all cars look the same.
Show below is a pictures of the passenger side braces on my April 1968 built convertible.
There is a second lower one that is hidden by the duct.
John
Old Dec 31, 2014 | 08:21 PM
Blue73Shark's Avatar
Blue73Shark
here is the page from my 1973 AIM:
Different from the ones shown previously.
Fran
Old Dec 31, 2014 | 08:33 PM
Paul L's Avatar
Paul L
Fran,
It looks like things differed from year-to-year.
Old Dec 31, 2014 | 10:20 PM
69monzacpe's Avatar
69monzacpe
Mine is an early 69 (Feb 1 build date) with A/C and had no brackets. When I looked around, the point where the large bracket should have attached on the right side dash below the post, there wasn't any marks where it would have been bolted in. Because of this, I assumed they were never installed and had not been removed by a previous owner. The picture attached isn't the best, but is the only shot (after I removed the dash) that I could find from several years ago.
Old Jan 1, 2015 | 03:15 PM
LRB's Avatar
LRB
Default Dash braces for convertible
73silververt,
I have a 75 convertible and when I opened mine up I found I was missing the 2 of the braces on the driver's side. I found them on ebay and ordered them and they should be arriving any day. I had to order all three braces on the drivers side, so I will have an extra 3962667 as seen on the attached diagram. I will be glad to sell it to you for what I paid for it.
PM me if you are interested.
File Type: pdf
To under dash bracing pics
