1975 roadster
Here's how it works- think of the day of the month that the two most important people in your life were born. Include yourself if you like as one of them. Almost invariably, the two people will not be born on the same day. Take the two numbers and subtract the smaller from the larger. That number is the '1 of' that you've been seeking.
Ex- one person was born on the 22rd, the other on the 18th. 22-18=4. Your car is 1 of 4.
For the rare case that both people were born on the same day, replace one of them with the number 15 and use the same formula.
If you really don't have two favourite people in your life and don't want to lie, there's an alternate method. Think of how many people have come up to you and told you the same old story like 'my uncle had one with a metal body', 'you should have got an LT-1 big block' 'I'll give you $5K for it right now' etc.
If the number exceeds what you want to hear, divide the total of one dumb comment by the total of a different dumb comment.
See, simple.
Where does that 366 L82 convertibles come from?
Its pretty close to random. You cannot project numbers that result from different people making individual choices. Numbers people quote are purely made up.
Calculating the amount of cars that year with a combination of NINE (9) options/choices is imaginary. If you are trying to be able to say it's rare, just say it's a high option car that was likely relatively rare.
Another common flaw in calculating numbers is not taking into account options that a given car does NOT have.
Ex- power brakes and power steering are very common. In just about every year, more than 50% of cars have one or both. This means that cars that do NOT have them are 'more rare'.
My car has deluxe interior, PS, PB, rear defrost but manual windows and no AC. Extra- extra rare I bet.
From a statistics perspective, if you multiply in a percentage for every option, whether high or low, you are accounting for it. So if 97% of cars had power steering, you are accounting for the rarity of the 3% of cars that do not.
Exactly, but I don't think the calculation is completely worthless. Maybe everybody should do it and discover like I did that long before you get to the bottom of what it does have, never mind what it doesn't have, the calc will show that the car is statistically less than 1 of 1.
How many of those 1975 convertibles even exist anymore ......probably less than half anyway if that.
I never saw but a scant few new back in the day.
All of this could improve the accuracy of an estimation by indicating 'more rare' or 'less rare' but if the crude and simplistic method I outlined above already indicated a less than 1 of 1 probability on a consistent basis, is there much point?
So what needs to be done is to calculate the combination with repetition. I don't just mean that someone who picks power steering may also pick power brakes. I mean take all the options available for that year and calculate the different number of combinations. Then using the known quantities of each RPO (and standard items) calculate the probability of achieving your specific combination of options (or standard items).
