poor quality replacement parts
Don't even get me started on the quality of the reproduction parts sold by Corvette America.......door panels.....plastic backing is too thick and the Velcro fasteners won't hold them in place......close inspection/comparison to the Velcro OEM mounts reveled that the ***** on the ends of the stems were too small and wouldn't properly grip the GM pads, made some " L " brackets and used them to hold lower panel to door frames. Corvette America dash.....upper panel required me to install some screws with fender washers on them to properly tension the fit as they screwed up on OEM retainer clip opening positions.......Corvette America windshield pillar moldings.....not even remotely close to fitting correctly.....same problem with Velcro ***** on the end of the stems but, this time the metal backing frame didn't allow the Velcro pads to engage after I wasted my time and mounted some GM pads onto the replacement moldings......used double sided foam tape to mount trim.....Corvette America parking brake cover studs pulled off of console cover after installation.....they were fastened with a thick plastic strip about 0.020" thick, I didn't excessively torque the retainer nuts.....this was just another crap part nothing like the GM design....just a cheap Chinese copy with no real thought to what GM had done. My Corvette America drivers dash panel was so poorly made I hunted on Ebay for a correct Used dash and paid plenty for one I needed to do a little epoxy repair to.....fit like a glove! Corvette America dash vent ***** that were soo far from being spherical that I had to remove some sealing felt to allow them to somewhat work.....Corvette America vents are best described as " egg shaped " the GM ***** were spherical basically round....how do you screw that one up?
Anyone who is in the market for a 1970 drivers side lower dash pad.....I'll sell you a brand new Corvette America pad for $150 no warranties or guarantees of correct fit/finish implied......
I had to order one from Corvette Image and it was the correct length and quality. I also ordered a replacement (not reproduction) rear license plate lens and did not like the quality. I gave it to the body shop that the car was at. Lou.
As far as tools go, I'll wait a little longer to buy a tool if I can find one that's quality.
I have 30M in a 49 chevy fleetline...will never build another streetrod. The parts you get now are JUNK!!!! PURE JUNK!!!
My one piece windshield from Thialand...is now a 3 piece. The twiwan one piece bumpers look great except when you install them...they are so soft they bend in at the bolts...terrible. The door stainless trim...looked good until I tightened it...my perfectly straight door is now called "Mr Wavy". I could go on and on.
Another thing...it does not have to be made overseas any more to be nothing but CRAP...a few of the parts made in usa were as bad as the china stuff...GREED is the decline of America and eventually will be its fall....sad but true.
I purchased a flex- fiberglass front bumper for my 73 from Paragon and it fits pretty dam good. Just too cold right now were I'm storing my car, to finish mounting it but it lined up without much fuss. lucky I guess.
Different people have different experiences. Ive had horrible experiences and would never go back with some vendors that people here absolutely love.
I think it's pretty much a coin toss.
I have bought stuff from most of the big Vette vendors, and I will attest to the terrible fitment of the corvette America interior parts...most all of them sucked and I sent them back and just dyed my original stuff that I could.
I will say I have had good luck with Corvette Central and their service, and best of all is Willcox Corvette.. Their service is outstanding and prices are the best. They are my first call for repro Vette stuff. They are also very helpful on the forum as well.
I haven't heard of this problem for a while so maybe it was only one batch of parts. Too bad that the offshore people cannot even copy correctly.
Jim
I thought Al Knock was the guru of top shelf tops, I likely would have bought from him but never doing a top before would I have been savvy enough to know the top was messed up like in Bj1ks case, I might have though the issue was with me,
The import parts are junk posts will never end, I know how anti American it is to buy any part not made in the USA, not all USA made stuff is great, ever shop us made stuff at walmarts?
I have seen a real close 50/50 to US made parts and import made parts and which are junk and which are great, ( purists aside from this )
I see post after post from people that say the import xxxxxxxx works just as well as the US one that costs 2-3 times more,
Some people simply can not afford to pay any extra just because it's made in USA.
I had a thread about tires, I made lots of calls and 15" tires are basically on the way out as far as any wide sizes go, I would guess places like Coker will sell stock sized 15" mostly bias plys but who really digs running bias plys?
Crappy parts hurt us all but I really see it being a stick stuck in and broken off for a purist who must have that factory USA made part in good quailty...
