Leaf spring taken apart
Old Jan 3, 2015 | 07:04 PM
mcltcb's Avatar
mcltcb
Default Leaf spring taken apart
I'm cleaning my spring and putting new paint and liners. My question is ,when I got it all apart there are 10 pieces. Is that the right amount of leafs?
Old Jan 3, 2015 | 07:38 PM
mcltcb's Avatar
mcltcb
Never mind. I counted wrong. There are 9 pieces.
Old Jan 3, 2015 | 10:08 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Don't feel badly about it......I put mine back together....cleaned out the parts-wash tank......had a short leaf left over....LOL
Old Jan 4, 2015 | 04:32 AM
rene040269's Avatar
rene040269
9 should be the correct number for a standard leaf spring, 7 if you have a gymkhana sport leaf spring.
Old Jan 4, 2015 | 08:24 PM
mcltcb's Avatar
mcltcb
Just found the other piece on floor. So there are 10pieces total. What's up with that?
Old Jan 5, 2015 | 11:51 AM
doorgunner's Avatar
doorgunner
LOL....join the Club!
MikeWard said some assemblies come with 10 pieces.
Old Jan 7, 2015 | 08:31 AM
Elpres27's Avatar
Elpres27
4th Gear
I'm doing the same thing and my spring got 10 pieces like yours 2.5 inches wide. I have a 79 and it isn't the original spring, I'm trying to find liners, if you find liners, let me know where you found them. Lot of 9 leaves liners kit available but 10 leaves kit are hard to find.
Old Jan 8, 2015 | 03:56 PM
doorgunner's Avatar
doorgunner
If one of the old leaf liners is in decent shape, cut it to the correct length to fit the 10th leaf........and use the 9-leaf liner kit for the other leafs.
Old Jan 8, 2015 | 04:49 PM
Red Vert 02's Avatar
Red Vert 02
I believe the steel rear spring was supposed to go from 9 to 10 leaves in 1975.
Old Jan 12, 2015 | 03:04 PM
Elpres27's Avatar
Elpres27
4th Gear
Tks, finally found a local spring shop that kept roll of liner. Already cut and installed.
Old Jan 12, 2015 | 07:36 PM
tltw72's Avatar
tltw72
Plastic or metal ?
Old Jan 12, 2015 | 08:18 PM
gsimon767's Avatar
gsimon767
I have a 75 with seven rear leafs that appear original. If it is the original spring can I assume this is a FE7 Gymkhana suspension. Could it be a ZO7? What do I look for to tell the difference?
Old Jan 16, 2015 | 08:43 PM
mcltcb's Avatar
mcltcb
How much does something like that cost?
Old Jan 18, 2015 | 09:35 PM
PeteL46's Avatar
PeteL46
Originally Posted by tltw72
Plastic or metal ?
A form of plastic. I would assume they acting as a lubricant or an anti squeek. You really don't want metal on meatal shifting parts.
At one time vendors offer them.
I'm not sure the amount of leaves in a 9 but 7's have 8. I believe the 8th is a spacer/straight piece that doesn't require a lining.
Regards,
Pete
If you can't find them for your years (C3) Long Island Corvett Supply offer for mid years, They'll probably work
Old Jan 19, 2015 | 09:13 AM
Elpres27's Avatar
Elpres27
4th Gear
Plastic or metal ?
Plastic, I put a picture of my old metal liner, as you can see it was in bad shape, the new one are made of hard plastic, bought 12 feet and cut them. Hope it will do the job.
Old Jan 19, 2015 | 09:21 AM
Elpres27's Avatar
Elpres27
4th Gear
I paid $7.00 per feet, bought 12 feet, $100.00 with taxes, probably paid too much but I was just happy to find them !
To Leaf spring taken apart
