1979 corvette short
Old Jan 4, 2015 | 10:10 PM
FlippinCorvette's Avatar
FlippinCorvette
Default 1979 corvette short
When you plug in the fuse to the radio, the battery slowly drains. It is NOT the radio draining the battery there is a short somewhere else but I can't find it. What should I do?! Continue to search ?? Or try to move the radio onto a different fuse by ripping out the wires and hooking them to a different fuse?? I don't know what else to do
Old Jan 4, 2015 | 11:14 PM
Cynical's Avatar
Cynical
I have my radio (Retrosound Model Two) wired to the battery. Everything else is tied into the wiring harness (power antenna, accessory, speakers). Maybe try running the hot wire from your radio directly to the battery? Works for me.
Old Jan 5, 2015 | 07:12 AM
65GGvert's Avatar
65GGvert
If you're sure it's not the radio, you need to get a wiring diagram and see what else is on that circuit. Maybe the clock or glove box light, I don't know what's on the same fuse.
Old Jan 5, 2015 | 07:39 PM
FlippinCorvette
That's what my radio is thank you!
Old Jan 5, 2015 | 07:40 PM
FlippinCorvette
If you run it directly to the battery tho won't it stay on all the time?
Old Jan 5, 2015 | 07:42 PM
Cynical's Avatar
Cynical
No, there is one wire that needs to be hot all the time from my radio. Wired that directly to the batter (this keeps the memory, etc). The other wire is tied into the accessory wires. When accessory turns on, the radio does too. Hope that makes sense.
Old Jan 5, 2015 | 07:54 PM
FlippinCorvette
Thanks man I really appreciate it
Old Jan 5, 2015 | 07:56 PM
Cynical's Avatar
Cynical
As a heads up i remember that the original radio did not have to be hooked up to the batter for memory like how new radios do. So that's why I just re-wired directly to the battery when installing the Model Two. Goodluck!
Joshua
Old Jan 5, 2015 | 08:52 PM
FlippinCorvette
Joshua
Ill still need to figure out where to hook my speakers because ether can't be hooked to the harness either, and ill need to think of a way to hide the wire to the battery
Old Jan 5, 2015 | 08:54 PM
65GGvert's Avatar
65GGvert
Wiring directly to the battery isn't going to change anything if you're already wired to a switched and non switched power as most aftermarket radios are. You can completely disconnect the always hot wire and you'll lose your station memory and clock time, but it won't drain the battery. You'll never know until you connect an ammeter in line with the battery and disconnect the power wire or accessories to find where the draw is. Moving from one constant 12v to another (the battery) won't change anything.
Old Jan 5, 2015 | 08:56 PM
Cynical's Avatar
Cynical
My radio came with an output to each speaker. I know the original radio had connectors that plugged into the back of the radio module and ran to their respective spots in the car. Newer radios should have outputs as well. Just run it under the carpet, or splice from the radio to the existing speaker harnesses to the new speakers. As for running the hot wire from the radio I took a long piece of wire from an old VW harness and ran it through the console, under the parking brake, behind the drivers seat, and up into the battery compartment. You are able to slide the wire through the compartment lids if you're smart about it. I can always get some pictures if you want, just PM me ahead of time.
Old Jan 6, 2015 | 02:53 PM
Tooonz's Avatar
Tooonz
One thing to check, if your radio is draining your battery is the ground wires going to the starter. There is a black wire, small in diameter with a connection end that looks like it goes to the larger post on the starter. That wire needs to be grounded to the block or transmission housing. That was my problem when searching for my radio drain. I knew it was the radio, someone on this forum led me to that wire.
Old Jan 7, 2015 | 09:07 PM
FlippinCorvette
Thanks man again
Old Jan 7, 2015 | 09:08 PM
FlippinCorvette
Thank you too
Old Jan 21, 2015 | 11:05 PM
FlippinCorvette
Default Solved
Installed kill switch days ago to the battery everything working as it should now
Old Jan 22, 2015 | 12:44 PM
Tooonz's Avatar
Tooonz
where was your short?
Old Jan 22, 2015 | 06:36 PM
FlippinCorvette
No idea, the car generates power while its on, and I just turn the switch and shut all power down from the battery when it's not on. So far it's working
To 1979 corvette short
