DeWitts or Be Cool Radiator???
Old Jan 6, 2015 | 02:42 PM
Vette79C3's Avatar
Vette79C3
Default DeWitts or Be Cool Radiator???
DeWitt's or Be Cool Aluminum Radiator for '79 Auto and Why? My last DeWitt's developed a leak around the overflow tube on the neck. Didn't seem like it was put together well. Never ever had a problem with cooling though. Let me know which one you would choose and why...
Old Jan 6, 2015 | 03:10 PM
widowmaker221's Avatar
widowmaker221
According to most here Dewitts is the Bomb!! This is on my short list too and I have actually been looking at Champion radiators because their price is much lower. On another note do you ever make it to the lost in the 50's car shows as I see you are local to me?
Old Jan 6, 2015 | 03:30 PM
Vette79C3's Avatar
Vette79C3
Wow, real local. Right down the road. Past couple years I've lost interest but recently picked back up my projects for my vette and hoping to be more involved this year. As for the Radiators, the DeWitt's and Be Cool's are very expensive. Just want one that will last. Champion's and some others are half what the better one's cost but you do get what you pay for. I've heard of the Lost in the 50's Car Show. where and when is it?
Old Jan 6, 2015 | 03:32 PM
qwank's Avatar
qwank
this one:
http://www.zip-corvette.com/catalog/...category/6937/
Old Jan 6, 2015 | 04:23 PM
Vette79C3's Avatar
Vette79C3
Originally Posted by qwank
This is what I would have to order from Zip:
77-82 w/Auto Direct Fit Aluminum Radiator
Item #: RA-166 $499.95ea.
Black Ice Coat For "Direct Fit" Aluminum Radiator
Item #: RA-192 $60.00
$603.69 including shipping to Md.
Old Jan 6, 2015 | 04:26 PM
zwede's Avatar
zwede
I like my BeCool. Got it 15 years ago and it's still like new. Never any problems with it and the car runs cool in TX heat with AC (and it's a big-block, too).
Old Jan 6, 2015 | 04:45 PM
widowmaker221
Marley Station Mall every Saturday night when the weather breaks! I drive my 79 there , 2 bucks to get in but goes for good causes and there is usually is a few c-3's there as well.
Old Jan 6, 2015 | 06:44 PM
asianlimodriver's Avatar
asianlimodriver
I just installed my DeWitt's radiator over the Christmas break. It definitely does the job. My car does not go over 160. The only drawback was that the factory mounted dual spal fans needed to be moved over about an inch to clear the control arms. The Champion radiator that I looked at would not have fit well into my 72 coupe without major modifications. Even the Champion rep that I was working with didn't think it would work. Since your car is a 79, you may have better luck. I'm a DeWitts fan at this point.
Old Jan 6, 2015 | 07:46 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Can you not get your DeWitts welded up to fix the leak?
Old Jan 6, 2015 | 08:17 PM
John 65's Avatar
John 65
Still have the rad? If so, then I agree with Gary, and would give Dewitts a call for their advice concerning the leak.
I also like that replacement unit of their's that Zip sells.
Have put Dewitts radiators in 3 of my cars through the years because of the quality, workmanship and dependability. Sorry, cant comment on Be cool, never had one. Hope it works out for you. Good luck.
Old Jan 7, 2015 | 04:56 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Dewitts is also a Corvette Forum supporting member, they also chime in giving expert advise. Suspect you can see whose product I like, but they don't supply you with an extra decal. That's a hint Tom. T
Old Jan 7, 2015 | 08:05 AM
4SPDL81's Avatar
4SPDL81
St. Jude Donor '16
I bought a DeWitt's radiator for my '81 4 speed because I could not find any other manufacturer ( at the time ) that offered a radiator without a built in automatic transmission oil cooler ( which, of course a standard trans car does not need )...and the other usual reasons for purchasing from DeWitt's...fit finish quality performance etc.....Good Luck!
Old Jan 7, 2015 | 10:34 AM
qwank's Avatar
qwank
why would you have to order that one for $200 more?
The one I listed should fit and is made by Dewitts. You can paint it black yourself.
Old Jan 7, 2015 | 10:43 AM
Vette79C3's Avatar
Vette79C3
Oh yes, I've been there several times. PM me so we can coordinate the next meet.
Old Jan 7, 2015 | 10:53 AM
Vette79C3's Avatar
Vette79C3
Yea, the first thing I did was contact DeWitt's and basically didn't receive positive response from them regarding the rad. Only 1 out of 3 emails were responded to. Was hoping for some sort of warranty, possibly sending the core back to be replaced or repaired, asking for a new neck, and my last email specified purchasing a new one outright and still no response. So, I know a welder who was able to weld the neck up along with the overflow tube. Unfortunately, welded the inside of the neck too and screwed up the ring surface where the bottom rubber of the cap mates. We did manage to grind down and create a flat surface and create a seal once the cap is installed. When the cap is installed and all ports are plugged, when I blow into the overflow tube, I can't blow, which is good but not sure I want to wing it with this patch work. So, basically on the inside of the hole where the cap goes there is no longer that raised ring where the rubber of the cal would mate.
Old Jan 7, 2015 | 10:55 AM
Vette79C3's Avatar
Vette79C3
What type of paint would I need? I'm under the impression you need a certain type of paint......
Old Jan 7, 2015 | 12:31 PM
widowmaker221
Cool, will do!
To DeWitts or Be Cool Radiator???
Old Jan 7, 2015 | 12:53 PM
63vette427's Avatar
63vette427
I went with a Dewitts and bought it through Willcox. They had a 20% off coupon that worked. I have been very happy with my Dewitts and was a perfect fit on my 71.
Old Jan 7, 2015 | 02:48 PM
finally kool's Avatar
finally kool
Cruising
Default dewitts problems
Because the dewitts radiator with double fans RESTRICTS air flow overall (when they are not on) and are constantly coming on/off . draining the battery by constantly cycling....( on my C3)
Last edited by finally kool; Jan 7, 2015 at 02:52 PM. Reason: forgot to add "on my C3"
Old Jan 7, 2015 | 06:13 PM
C3 Stroker's Avatar
C3 Stroker
Eastwood's Radiator Black Paint. That's what I used. Over 10 years and still good. It is a high temp. laquer type (but acrylic enamel) paint. Don't use the enamel types from part stores....they will clog the rad's airflow.
Here.......http://www.eastwood.com/eastwood-rad...ack-paint.html
