DeWitts or Be Cool Radiator???
Old Jan 7, 2015 | 09:35 PM
Vette79C3's Avatar
Vette79C3
Originally Posted by C3 Stroker
Eastwood's Radiator Black Paint. That's what I used. Over 10 years and still good. It is a high temp. laquer type (but acrylic enamel) paint. Don't use the enamel types from part stores....they will clog the rad's airflow.
Here.......http://www.eastwood.com/eastwood-rad...ack-paint.html
Thanks.
Old Jan 7, 2015 | 09:37 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Our product for painting aluminum radiators (or suspension parts)
http://www.dewitts.com/collections/a...ducts/blackice
Old Jan 7, 2015 | 10:01 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Originally Posted by finally kool
Because the dewitts radiator with double fans RESTRICTS air flow overall (when they are not on) and are constantly coming on/off . draining the battery by constantly cycling....
We have twelve (12) free flow flapper check valves that open if any back pressure is present
and fans cycling on/off is normal.
Old Jan 7, 2015 | 11:02 PM
speedreed8's Avatar
speedreed8
Because the dewitts radiator with double fans RESTRICTS air flow overall (when they are not on) and are constantly coming on/off . draining the battery by constantly cycling....( on my C3)
it would appear you have them wired incorrectly, if they are draining the battery. or your alternator is not up to the task....
Old Jan 8, 2015 | 12:19 AM
68/70Vette's Avatar
68/70Vette
I have a Be Cool BB radiator in my 68 for a ZZ4.
I'm going to be building a 496 or 502 BB engine and I hope to get 600 hp. De Witts sells BB stock aluminum replacement radiators for 454's, but last time I looked, I didn't see any information as to their applicability for 496/502 engines running at the ~600 hp range.
Old Jan 8, 2015 | 08:22 AM
540 vette's Avatar
540 vette
I have a Champion in my car and it fit great and cools the car. I also have a set of fans I bought on E Bay that look like the Spahl fans. They also work great with no problems with both parts.
Old Jan 8, 2015 | 08:27 AM
540 vette's Avatar
540 vette
Originally Posted by asianlimodriver
I just installed my DeWitt's radiator over the Christmas break. It definitely does the job. My car does not go over 160. The only drawback was that the factory mounted dual spal fans needed to be moved over about an inch to clear the control arms. The Champion radiator that I looked at would not have fit well into my 72 coupe without major modifications. Even the Champion rep that I was working with didn't think it would work. Since your car is a 79, you may have better luck. I'm a DeWitts fan at this point.
What major mods could it possibly need to fit the radiator.
Old Jan 8, 2015 | 08:29 AM
540 vette's Avatar
540 vette
Maybe you should get a different alternator to handle the bigger load.
Old Jan 8, 2015 | 08:59 AM
Vette79C3's Avatar
Vette79C3
If DeWitt's would respond to my emails I would have possibly already purchased a Rad. Can you PM to discuss product and pricing?
Old Jan 8, 2015 | 09:07 AM
John 65's Avatar
John 65
My buddy has a 509 Merlin with that kind on HP with AC also in his 69. The Dewitts unit with the 2 fans works like a charm. They cycle on at 195 and back off at 180. Its amazing.
Old Jan 8, 2015 | 11:39 AM
bashcraft's Avatar
bashcraft
Why is that amazing? I have a 509 with 550 hp in a '69 that is being cooled by the factory copper/brass small block radiator and 7 blade clutch fan. It's never gone above 190.
Old Jan 8, 2015 | 12:40 PM
John 65's Avatar
John 65
I wish I could say that.
When I swapped over to a 454 I had to upgrade the cooling system.
Old Jan 8, 2015 | 01:36 PM
  #33
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
I don't PM as I participate on several fourms and that would be just too many things to manage. You can email me directly at tom@dewitts.com
Old Jan 8, 2015 | 04:15 PM
  #34
asianlimodriver's Avatar
asianlimodriver
When I went to check out the Champion radiator, I brought along my stock radiator. Keep in mind that it's going in a automatic 72 small block with air. When I compared the champion to the stock side by side, the Champion was significantly thinner than stock. The stock radiator brackets would have had quite a bit of play. Also, the Champion did not have the dimple on the bottom hose outlet and would have given me clearance issues. When I spoke to the guy that sells the Champion radiator, he agreed that it would not fit. He even took pics of my radiator to forward on to Champion to address the issues. I think the Champion radiators made for the later 70's vettes would fit much better. It appears that they are different than the 72 radiators.
Old Jan 8, 2015 | 04:56 PM
  #35
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
I have a Be Cool rad that fit perfect and has never been a problem over the last 10yrs. I am also using a Spal fan.
Old Jan 8, 2015 | 07:51 PM
  #36
The13Bats's Avatar
The13Bats
DeWitt's or Be Cool Aluminum Radiator for '79 Auto and Why? My last DeWitt's developed a leak around the overflow tube on the neck. Didn't seem like it was put together well. Never ever had a problem with cooling though. Let me know which one you would choose and why...
Yea, the first thing I did was contact DeWitt's and basically didn't receive positive response from them regarding the rad. Only 1 out of 3 emails were responded to. Was hoping for some sort of warranty, possibly sending the core back to be replaced or repaired, asking for a new neck, and my last email specified purchasing a new one outright and still no response. So, I know a welder who was able to weld the neck up along with the overflow tube. Unfortunately, welded the inside of the neck too and screwed up the ring surface where the bottom rubber of the cap mates. We did manage to grind down and create a flat surface and create a seal once the cap is installed. When the cap is installed and all ports are plugged, when I blow into the overflow tube, I can't blow, which is good but not sure I want to wing it with this patch work. So, basically on the inside of the hole where the cap goes there is no longer that raised ring where the rubber of the cal would mate.
I am a bit surprised about the customer service you received or well, lack there-of from Dewitts but now that Tom is involved in this thread I am interested in his response to your issues.
I took a long time to research radiators and gave Tom a lot of hell I also have given a lot of hell to people like 540 vette, I bought from Dewitts but if I had to do it all over again I would have to think hard about it.
I have started more than one thread talking about radiators and fans trying to gather more real world tech and for the most part the answer is ( if it isn't someone scolding me for even asking ) "it worked great on my car" that just isn't good enough for my quest for more tech.
Most people make a post about radiators only after they are having cooling problems, and the fact is If the car is bone stock or even mild in most cases a b/c replacement will fix their problems,
When one looks at the price of the "import/cheap" aluminum units it's hard not to just step up to one of them, then of course if a person has a modded engine/car and things like auto trans and/or AC they might start thinking they need all they can get the best they can get,
( where I was ) sometimes the best one can get costs the most, not every time,
"Getting what you pay for" shouldn't be used as an excuse for over paying.
I see 540 vette used the Ebay no name Spal dual fans that can be had for around 120.00 shipped,
he runs the Champion import Aluminum radiator and reports no problems cooling his beast.
I have no idea what finally Kool is talking about, the dual 11" fans have trap doors for allowing airflow when the car is moving fast enough and fans do cycle on and off, most all new cars have electric fans that do that, if your battery is draining your alt is too low, I have a alt that is just at 100 amps and never an issue.
The dual 11" doesn't restrict airflow but what I don't care for is how much of the radiator is not covered with shroud, there are several fan set ups that do cover more if not almost all of the Radiator, they are newer models than the 8 or 10 yo 11" duals.
I would have to say that fitting the Champion is hit or miss, people who sell Champion are not "vette" people they are car parts people like the kid selling you a air freshener at pep boys, but if you are into saving a buck and working out possible issues then this might be worth a look.
To the OP, the world of radiators is larger than one forum decide what you really need, and if "bragging rights" are worth 100's to you,
then buy the radiator you want based on your needs....
Old Jan 8, 2015 | 08:23 PM
  #37
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Overflow tubes have been damaged in shipping and sometimes they will just have an annoying drip. We have changed our packaging so the radiators cannot slide left to right anymore.
It sounds like you already repaired this issue, but if you want to have us look at it I would be happy to fix it for you. You send it to me, and I'll send it back to you with a new filler neck. I'm sorry you didn't get the email response you deserve.
If you are shopping for another radiator, hang in there because our annual sale is next week.
To DeWitts or Be Cool Radiator???
Old Jan 8, 2015 | 08:31 PM
  #38
gearbreaker's Avatar
gearbreaker
I ordered a dewitts sbc/man radiator the end of December. ups dropped it off today. sure looks pretty in that box.
Old Jan 9, 2015 | 12:13 AM
  #39
68/70Vette's Avatar
68/70Vette
THANKS Like to hear that. I like to spread my purchases around. I've heard a lot of good things about DeWitts. I've now a BeCool on the 68, and so maybe DeWitts on the 70, the dual fans look nice in the photos.
BTW. The 68 has a ZZ4 stock SB engine. When I ordered a BeCool radiator, I ordered a single fan BB radiator!!! Engine runs cold even with 100% ethylene glycol.
Old Jan 9, 2015 | 01:43 AM
  #40
SI67's Avatar
SI67
Why would one run undiluted glycol in the cooling system?
Steve
