Power antenan problem 79
Old Jan 17, 2015 | 04:03 PM
Tooonz's Avatar
Tooonz
My last drive of the year I shut the car off the antenna went down then the motor kept running. I disconnected the battery and said night night for the winter. Planning for the spring I figured I'd ask now if this is a big deal or not? The mast is fine, and the motor runs,
Sorry for the spelling error my fat fingers strike again
Old Jan 17, 2015 | 04:38 PM
gbvette62's Avatar
gbvette62
The mast is raised and lower by a nylon cable, attached to the mast. If the motor runs, but the mast doesn't move, I'd say your cable broke. You can get a new cable and mast for around $40.
To replace the cable. you have to remove the antenna from the car, and open up the antenna motor.
Old Jan 18, 2015 | 03:29 AM
alconk's Avatar
alconk
Yep just happened to me, exactly what you describe.
Old Jan 18, 2015 | 08:30 AM
Lakeside49's Avatar
Lakeside49
The stock antenna is built better than any of the replacements, so it is worth the well-documented and satisfying DIY effort to replace its broken internal nylon cord - and, replace the old, congealed grease in the gear housing while the 'patient' is opened up on the table. I gave its black plastic antenna housing a shot of silver paint to help keep the heat-soak temps down slightly because of its proximity to the left (driver's side) muffler. Good luck.
To Power antenan problem 79
