Help trouble shooting Headlights!!!
Old Jan 19, 2015 | 01:02 PM
Jantonb's Avatar
Jantonb
Default Help trouble shooting Headlights!!!
Hey guys,
I'm rebuilding my headlight assembly and adding new bulbs, ect. The passenger side lights would come up slowly and over a period of time would not come up at all. Thinking it might be the actuators, I went ahead and replaced both of them. I still have the same problem. What do you guys think? Relay? Hoses look good.
Janton
Old Jan 19, 2015 | 02:07 PM
Dave J's Avatar
Dave J
Assuming your new actuators are good, the relays are your problem. You can test them before you throw more money at your problem fairly easily.
Mark your relay hoses and disconnect the lower and middle relay hoses. Using a short test hose, hook it up to the middle relay port. While blocking the lower port with your finger, try to blow through the relay. You should not be able to do this. If the relay leaks doing this test, the internal piston seal is shot.
If the relay(s) are bad, do not throw them away if they are original. They can be rebuilt. Also, before you spend good money on new ones, make sure the vendor checks the relays before they ship them, like Wilcox does.
Old Jan 19, 2015 | 03:27 PM
Jantonb's Avatar
Jantonb
Default Thanks Dave!
Thanks Dave! Question...If I swap relays, won't the problem follow to that side? I tried that and only the driver side still comes up and not the passenger side. Same problem.
Old Jan 19, 2015 | 03:36 PM
Jantonb's Avatar
Jantonb
OK…tested using your method with the short hose. Both relays are good! I could not get any air through, blowing into the middle (yellow) while blocking green with my finger. (red ports and metal ports not connected and open)
Ideas? Can?
Old Jan 19, 2015 | 04:41 PM
Dave J's Avatar
Dave J
Next step, do you have a vacuum gauge or better still, a mityvac vacuum pump?
I'll check back in a little bit.......
Old Jan 19, 2015 | 04:48 PM
Jantonb's Avatar
Jantonb
a vacuum gauge yes
Old Jan 19, 2015 | 05:08 PM
Dave J's Avatar
Dave J
Next you need a "T" connector to put your vacuum gauge in series with the vacuum hoses. Connect it between the suspect actuator and the relay. The reading should be the same as your engine's vacuum reading.
Next, I use a needle nose vice grip pliers to pinch closed the vacuum line between the gauge and the relay before you turn the engine off. You should NOT observe any vacuum loss after shutdown.
Old Jan 19, 2015 | 06:07 PM
Jantonb's Avatar
Jantonb
I do have a mityvac…yes
Old Jan 19, 2015 | 06:22 PM
Jantonb's Avatar
Jantonb
When you do this test, should doors be up or down? Do you put the gauge in series on the green line or red line? Or does it matter?
Old Jan 19, 2015 | 06:43 PM
Dave J's Avatar
Dave J
Good! Forget the vacuum gauge for now. Keep the engine off. Pull the actuator hoses off front and back. Pull the headlight up one at a time, and connect the Mityvac to the front actuator port. Then simply pump it up. It should hold vacuum. Do this to each side.
Next move the headlights down one at a time. Put the Mityvac on the rear port of the actuator, and pump it up. It should hold vacuum. Do this to each side.
This is the best test of the actuators. If they test OK, you can move to the next test.
Old Jan 19, 2015 | 07:23 PM
Jantonb's Avatar
Jantonb
Default OK…we are on to something!
OK Dave…I think we have something!
Drivers side (the one that works when all hoses are hooked up) = Closed the light, removed all hoses, hooked minivac up to where the green connects on the actuator (bottom)….the headlight raised! Hooked mini vac up to the top port where red connects….the light closed!
Passenger side (the one not working)…did the same test as above…nothing. The light did not close or open.
Bad actuator? What do you think?? It's brand new? How could this happen???
Old Jan 19, 2015 | 08:03 PM
Dave J's Avatar
Dave J
I like it when a plan comes together!
If you would continue to pump the Mityvac at the end of headlight travel, the gauge would show increased vacuum with each additional pump if the actuator is sealed. If you left for an adult beverage break and came back a short while later, the gauge shouldn't move in a perfect actuator world.
Open the passenger side headlight and test the front port again. With the headlight already raised, a good front actuator seal would allow an increase in vacuum when pumped for a minute or so. The front seal can be replaced. Close the door, and test the rear port. You should get some vacuum in the same amount of time. Rear seals cannot be repaired. If no on either test, the actuator is bad. If new, send it back.
Not surprising at all. Seems all some suppliers and manufacturers care about is $$$$$. Slap stuff together, and don't check it for leaks is how some of them work.
If you still have your old actuators, check them. Check the rear ports first. If you have a good one, then check the front port. Remember, front seals can be easily replaced.
Good luck........Dave
Old Jan 19, 2015 | 11:52 PM
68/70Vette's Avatar
68/70Vette
I bought new repro vacuum actuators for my headlights, only because they looked new. About three years after installation, one of them stopped working due to leaky seals. I replaced it with one of the original vacuum actuators which, of course, still works fine.
Repro stuff!!!
Old Jan 20, 2015 | 06:40 AM
MrM1978's Avatar
MrM1978
Good info. I am having similar issues with my right side. I'm about 95% sure there is a leak up front that is effecting my #4 and #8 cylinders. Plugged off the hose to the engine and cars runs very good. With vacuum hoses hooked up correctly, car runs rough off the start. There is another thread here about the engine running lean I placed that describes all the preliminary test that were done prior to this determination.
Replaced all the vacuum lines up front so I know they are good. I purchased new actuators but have not installed them yet. Want to test the relays first, hope to do that this week. Almost to the point of replacing all so everything is new but after reading a few post, I see there is a chance the new parts could leak as well. Going to try to do the test this week-end and see what I come up with. Any other suggestions are welcome. Will let kyou guys know how things turn out. Thanks.
Old Aug 24, 2015 | 10:06 PM
Jantonb's Avatar
Jantonb
Thanks to Dave the Corvette Guru….problems have been solved! All is good and looks great! Thanks again Dave for all your input and help!!!!
Janton
Old Aug 24, 2015 | 11:18 PM
Dave J's Avatar
Dave J
Wow, you have a good memory! It's been a while. Glad you got things figured out!
I like happy endings
Old Aug 25, 2015 | 06:15 AM
Jantonb's Avatar
Jantonb
I like happy endings as well! :agree:
Now this is happening….Just re-did the doors…new regulators, new motors, new power lock motors ands switches, new pig tails, new panels…the works! Got everything buttoned up and cool all in the world is fine!!! 2 days later, boom…all of a sudden, no windows! When I work the center console switches, it's drawing power (lights dim), so I know power is to the switches…took off the door panel and checked the motor wires with my multimeter…power there…positive and negative (reverse polarity) when flipping the switches. Replaced the 30amp 12 CB. No Dice! Still the power draw on both sides when working the switch. (power dim).
So….what am I missing? I'm totally out of ideas! Everything was working great…then both went out at the same time….
Old Aug 25, 2015 | 09:11 AM
marshal135's Avatar
marshal135
Veteran: Marine Corps
Dave just finished up helping me a month or so ago.
My problem was a defective new P/S actuator I assumed was good.
I purchased them over the winter of '14 on Ebay from a vendor.
They didn't last.
Orig. is the way to go.
Relays work great Dave by the way.
Thanks,
Marshal
To Help trouble shooting Headlights!!!
